820-00850-A Boot Looping
  • tonylock
    • Jul 2014
    • 10
    • Spain
    A customer brought in an A1989 logic board that is in a boot loop.
    It chimes and the backlight flashes briefly and does it all over again. The CPU gets warm as do the SSD, U2800 and UB00. It let me rebuild bridge OS sucesfully in DFU mode with no change.
    All USB ports get 20v and go up to 0.456ma and then down again in the loop.
    The board is clean, there are no signs of liquid damage or corrosion. The customer said it just wouln't start one day for no reason.
    Some of the voltages I checked are as follows:
    PP3V3_G3H - 3.35v
    PP5V_G3S - 5.12v
    PVCCEDRAM_S0_REG_R - 0v
    PPVCCGT_CPU_PH3 - 0v
    PPVCCGT_CPU_PH2 - 0v
    PPVCCGT_CPU_PH1 - 0v
    PPVCC_CPU_PH1 - 0.656v
    PPVCC_CPU_PH2 - 0.655v
    PPVCCSA_CPU_R - 0.813v
    PP0V95_S0_CPUVCCIO_REG_R - 0.953v
    PP1V2_S3_REG_R - 1.2v
    PPVIN_S0SW_LCDBKLT - 0.012v
    P5VUSBC_T_R - 0v
    P5VUSBC_X_R - 0v
    PP0V9_SSD0 - 0.899v
    PP1V8_SSD0 - 1.799v
    PP2V7_NAND_SSD0 - 2.5v
    ALL_SYS_PWRGD - 1.7v
    Any advise would be a great help.
  • TechSplendid
    • Oct 2023
    • 14
    • Gelderland
    Did you ever find out what the problem was? I seem to have the exact same thing.
    • mon2
      • 13940
      Carefully measure the voltage to ground of the battery connector. Check the smbus scl & sda line voltage.
      • Problematic G3nius
        • Jun 2024
        I also have a device that I'm working on that has this same issue. It attempts to boot pulls about 19 watts then shuts off. The device came in with an aftermarket battery, Iswapped it for a known good one but still the same issue persist. Any suggestions?
        • Takeatry
          Yet another Samsung QLED Boot Loop
          by Takeatry
          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
          10-04-2024, 02:57 PM
        • blaster_
          Samsung UE49MU6105K - boot loop, horizontal lines
          by blaster_
          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
          06-22-2022, 05:19 PM
        • torchzack
          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
          by torchzack
          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
          08-28-2023, 07:42 AM
        • No Lan
          [Macbook pro A1708] [Boot loop] [Trackpad ?]
          by No Lan
          Hey everyone,
          Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
          Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
          Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
          05-24-2025, 03:09 PM
        • trbovan
          Asus GL731GT Boot loop
          by trbovan
          Laptop is a GL731GT with the I7-9750h and GTX1650.
          Full model number is gl731gt-rb71-cb
          Serial: (placeholder for when I get home)
          Board model: G531GT REV. 1.5
          Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
          I assembled and tested anyway. The bios worked, I was able...
          10-04-2023, 07:27 AM
