lenovo y520 fan2 always full speed problem
  • swammyw
    • Apr 2021
    • 66
    • finland
    i had broken (no power) lenovo y520-15ikbn mboard: nm-b191
    i changed ec sio chip and laptop started working exept fan2 is always full speed
    i noticed after i soldered ec sio chip that fan2 pins: +5VS_FAN2 and EC_FAN2_SPEED was bended together, so i thought ec sio chip was damaged and i changed another one ec chip but same behavior occurs, also tried with another fan assembly (i have 2x y520 laptops) but still same story, what controls the fan speed if it is not the ec sio chip, i tried to figure it out from schematics but no luck, i hope somebody can help me with this thanks
  • mon2
    • Dec 2019
    • 14664
    Re: lenovo y520 fan2 always full speed problem
    On the fan connector should be a PWM signal. This PWM pulse stream defines the speed. It is also possible that a temp sensor is not working and causing the fan speed to be high. What does the bios report for temps? Are they high or normal readings?
    • swammyw
      • Apr 2021
      • 66
      • finland
      temps are around normal idle temps when i monitored them, lenovo diagnostics shows fans diagnostics not available?, could it be that pwm or speed pin from sio is badly soldered on board?
      • mon2
        • Dec 2019
        • 14664
        On PWM, if the voltage is the max (ie. ~3v3) then the fan will be @ max speed.
        Respectively, measure the voltage to ground on the PWM pin - even better if you have a scope to monitor if there is a pulse stream on this pin or is it a static voltage level.
        Can you link or post a schematic for this logic board?
        Will check my database in the meantime. Found far too many iterations of this model. Which one is yours?
        • swammyw
          • Apr 2021
          • 66
          • finland
          btw pins were bent together from the fan connector, could that have been destroyed the original sio
          • mon2
            • Dec 2019
            • 14664
            Yes, it is possible. The PWM (pin #3) is an OUTPUT from the SIO.
            The TACH (pin #2) is the voltage OUTPUT from the fan as it spins.
            Two outputs bashing each other never ends well. Proceed to measure the PWM voltage from the SIO with the fan installed.
            Also check the TACH voltage from the fan itself.
            BTW - Is FAN #1 working ok ?
            Post a picture of the fan connector so we can review the wires.
            You may be able to swap the FAN #2 wires onto the FAN #1 SIO pins for testing of FAN #2. That is, can the SIO pins for FAN #1 control the fan OK ?
            • Sephir0th
              • Oct 2020
              • 1289
              Worth to check whether the load switch U56 is internal shorted between Pins 1/2 and 13/14. I'm dealing with this kind of fault from time to time.
              FairRepair on YouTube
              • swammyw
                • Apr 2021
                • 66
                • finland
                yes, fan1 is working fine
                • swammyw
                  • Apr 2021
                  • 66
                  • finland
                  got fan 2 working, ec fan 2 pwm pin was not sodered properly to mboard
                  • Andreasbest
                    Lenovo Legion Y520-15IKBN Display works only through HDMI
                    by Andreasbest
                    Hello!
                    I received a Lenovo Legion Y520-15IKBN with blank screen but working display though HDMI.
                    Since customer was curious and disassemble it himself before bring it to me i want to check the JEDP1 backlight fuses but i can't find them!
                    Can you please point them to me?
                    Thank you in advance!
                    Schematics & Boardview attached
                    Boardview - https://www.badcaps.net/forum/troubl...o-y520-nm-b191...
                    02-18-2025, 05:45 AM
                  • coasterghost
                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                    by coasterghost
                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                    System Hardware:
                    Processor: AMD Ryzen 7 PRO 5850U
                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                    09-08-2025, 10:46 PM
                    LENOVO Legion Y520 Legion i5-7400 Specification for Upgrade or Repair
                    This specification for the LENOVO Legion Y520 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y520 boardview and Legion Y520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                    09-12-2024, 02:30 PM
                    LENOVO Legion Y520 i5-7400 Specification for Upgrade or Repair
                    LENOVO Legion Y520 Legion i5-8400 Specification for Upgrade or Repair
