acer E1-530 SHORT GFX
  • mo000
    • Nov 2017
    • 276
    • algeria
    Hi everyone
    the laptop comes to me dead i repair the power issue but the laptop power on with no data
    after checking i found the cpu vcore but no gfx vcore and i get 0ohms with the gnd on PL701 is that means the cpu is defective ? .
  • mon2
    • Dec 2019
    • 14197
    Re: acer E1-530 SHORT GFX
    Be sure you are using the lowest scale on your meter for the resistance mode checks of low voltage rails. NO POWER to the logic board when performing diode or resistance mode checks.
    For low voltage rails, expect the resistance to be low (1-2 ohms to ground is considered ok on some CPUs) but 0 ohms denotes a short on the CPU or a capacitor on the rail. First confirm the meter setting but the next step is to usually, use a power supply at a low voltage setting = lower than the lowest voltage on the logic board. Then inject onto the rail that is showing this low resistance. Who is heating up upon injection??
    If it is the semiconductor, then the component may be shorting. Otherwise, a capacitor may crack under such an injection -> remove the capacitor if present and test again.
    • mo000
      • Nov 2017
      • 276
      • algeria
      thnks for respond
      i inject 0.7v i get 0.15amps consumption but nothing becomes warm .
      • mon2
        • Dec 2019
        • 14197
        0.7v i get 0.15amps
        0.15A = 150 mA = will not cause a heating. This is not a short condition.
        • mo000
          • Nov 2017
          • 276
          • algeria
          but when i desolder PL701 i get 0 ohm on the side of GPU .
          i check the capacitors no short .
          • mo000
            • Nov 2017
            • 276
            • algeria
            yes it's not a short condition
            but what make black screen every voltages is OK
            i flash bios with tested file but same thing
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • jm942
              Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
              by jm942
              My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
              I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
              I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
              I did voltage injection on the cpu with 0.7V and i have a current...
              07-11-2024, 05:11 AM
            • 2Stupid4U
              Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
              by 2Stupid4U
              Laptop data:
              NTB Acer An517-51 FHD
              i7-9750H
              16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
              1TB SSD
              RTX2060
              Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
              Search gave me no hits so this is my first post.
              My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
              Since I am on a low budget I cannot afford to buy...
              08-29-2023, 01:03 AM
              09-06-2024, 05:27 AM
              Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
              This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
              09-07-2024, 05:00 AM
