How to Test if Laptop is Charging The Battery
  • Zentech
    • Feb 2021
    • 94
    • Usa
    guys, I have a laptop hp chromebook 14 and the operating system was not recognizing the battery. I opened and tested the battery connector to the motherboard for output. I found like three different voltages must of them 3.3V. Then I looked online for voltage of motherboard to battery in HP laptops and found the pinout of the connector. Needless to say I was surprise to see that the laptop doesn't charge the battery with 12v. I tested with the meter and it was like 3.3V in three different pins and two of them were ground. Then I search for articles on how to test battery and found this
    http://kuzyatech.com/testing-laptop-...harge-capacity
    my question is how can you really be sure the laptop is properly charging the battery and the problem is the battery and not the motherboard. what are the voltages on that connector. The curious thing is that when you unplug the charger the laptop provides 12V back to MB. How is that if it charges only with 3V.
    Thanks to all in advance
  • mon2
    • 14808
    Re: How to Test if Laptop is Charging The Battery
    Hi. Hope it is warmer there than here.
    1) Post any silk screen markings on your logic board. Perhaps, with some luck, we can find a schematic.
    2) Review the battery connector and surrounding parts. If possible, take clear and zoomed up pics of the area. You should find a square charger IC with perhaps the markings of 'BQ' = Texas Instruments. They apparently sold billions of these charger ICs to the industry. Once we know for sure which one is onboard, we can study reference schematics to review your logic board.
    3) At this time, suspecting that your logic board is NOT charging the battery due to the low charging voltage but could be wrong. The 3v3 you are reading are the SMBUS interface pins (SCL / SDA) that are used by the host SMBUS master to extract stats out of the BMS (battery management system) which is inside the battery pack under test.
    4) Once you remove the adapter, the voltage that is left on your battery is used to power the board = ~12 volts.
    Q1: What is the adapter voltage for this laptop? Is it ~19 volts ?
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
    • piernov
      Laptop battery charging circuit
      by piernov
      1. Some theory
      1.1. Introduction
      Almost every laptop has a charging circuit of some sort, that does a few things:
      • Manages switching between AC adapter and battery power
      • Manages battery charging and generates power rail to charge battery
      There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
      • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
      • Narrow VDC (NVDC)
      Texas instrument has a nice overview of these technologies with some more details at https:...
      11-15-2020, 01:31 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
