a1990 820-01326 no wifi/bt
  • phantomEVO
    • Mar 2013
    • 509
    hi guys! please help me! motherboard with shorted wifi, replaced from donor board + 2 eeprom...no luck...any idea?
    WLAN_PWR_EN
    PP3v3_g3s_wlan
    pp1v8_g3s_wlanbt_vdd
    all present
  • phantomEVO
    • Mar 2013
    • 509
    Re: a1990 820-01326 no wifi/bt
    no one?!
    • corrize
      • Apr 2021
      • 294
      • France
      Hello, I guess there is not enought details and your pictures have too low res, we can't see anything.
      I know new chip must have at least same wifi version than original, not under (for security) else bios block the working.
      • phantomEVO
        • Mar 2013
        • 509
        you are right: here it is!
        what do you mean with "wifi version?"
        • corrize
          • Apr 2021
          • 294
          • France
          I don’t saw it’s apple laptop. I don’t know these laptops.
          In pc world, the wifi version is writed in bios chip. If you replace a wifi chip v4.1 by v4, the bios block. But version 4.2, 5, 6, ok.
          So check if the chip is really the same : same version wifi.
          • phantomEVO
            • Mar 2013
            • 509
            This is a MacBook Pro…
            • phantomEVO
              • Mar 2013
              • 509
              please help
              • phantomEVO
                • Mar 2013
                • 509
                • mon2
                  • Dec 2019
                  • 14679
                  Personally do not have experience with this area but let us give it a stab.
                  The wifi / BT module will often be a stand alone unit that communicates with its master over UART or some similar interface (SPI / I2C / SMBUS). It appears this module uses UART mode with CMOS voltage levels (ie. NOT RS232).
                  In the schematic there are some multiplexers (MUX) devices shown @ U3640 and U3650. These devices must be enabled with the OE# signal. This is an active LOW signal.
                  If the pin #8 of each mux is LOW (0 volts), only then will the signals pass through the WIFI / BT module to the PCH (master).
                  Can you confirm the voltage to ground of the BTUARTMUX_OE_L signal ?
                  The MUXs have to enable so that the module can be configured & data can flow to / from the WIFI module to the host.
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    WiFi goes through PCIe, other busses are way too slow.
                    • mon2
                      • Dec 2019
                      • 14679
                      Well noted.
                      Confirm that each of the PCIe series caps are present onboard and that they are not defective. A defective / missing cap can halt the enumeration of the PCIe WIFI / BT module.
