Macbook Pro 2015 (A1398) 820-00138-A doesn’t wake up when using macOS
  • bogosort
    • May 2022
    • 78
    Hello everyone !
    I have an A1398 Macbook Pro (820-00138-A) that can't wake up from sleep, but only in macOS (tested with Monterey). Strangely, it does wakeup when using Windows 11. What could cause this issue? A sensor? Thank you!
    Here are some photos of the logicboard
  • mon2
    • 14415
    Re: Macbook Pro 2015 (A1398) 820-00138-A doesn't wake up when using macOS
    Long night ??
    Check the trackpad / SMC_LID voltage to ground when the lid is open. Remove the trackpad cable and test again.
    • bogosort
      • May 2022
      • 78
      Originally posted by mon2
      Long night ??
      hehe
      *Sorry for the lack of basic knowledge, I am still learning*
      When you say "voltage to ground", you mean red probe on the SMC_LID / trackpad test pad and black probe on ground while in voltage mode (and the macbook has power)?
      Not sure if this helps but, when trying with the trackpad disconnected I get the same problem.
      There is also this spinning wheel that keeps appearing everywhere during boot
      Thank you!
      EDIT:
      Oh and it got stuck on the loading screen when trying to start from internet recovery. I could however hear the voice-over so it was not frozen
      • bogosort
        • May 2022
        • 78
        bump
        • mon2
          • 14415
          Your internet connection may be faulty. Would you have a wired internet adapter that is compatible with the MAC world? Often the ones with the ASIX Ethernet controller are Plug & Play. That is recommended.
          If this approach is not working, review:
          https://discussions.apple.com/thread/7720550
          A good option is to try a bootable DVD from Apple.
          • reformatt
            • Feb 2020
            • 1431
            Spinning wheel reminds me of what iPhones used to do with crook batteries (tries to shut down due to low battery voltage). Try with a known good battery (and not some eBay knock off purporting to be genuine either).
