Microsoft surface 1769 SSD NAND replacement
  • magneh
    • Apr 2014
    • 591
    • Portugal
    Hello
    I got this surface with bad SSD, full of bad blocks.
    The original NAND is intel SSDPEBKF128G7
    Ive ordered an intel SSDPEBKF256G7 to double the hard drive space.
    NAND flowed in place well so I dont think soldering was a problem
    No shorts and resistance seems good in SSD line.
    BUT, when installing windows, no HDD detected on the drive list...
    Does the bios need to be worked?
    What am I missing?
    Has someone done these NAND replacements on these devices that could help me here?
    Thanks in advance
    Original Bios and photos in attachment
  • zakin
    • Jul 2013
    • 5
    • Moldova
    Re: Microsoft surface 1769 SSD NAND replacement
    Bad soldering, bad IC. It should work without any modification. Check voltage on L43002 and L43001
    • rediii
      h???, spurrrn
      • Mar 2018
      • 490
      • somewhere in europe
      is the ssd present in bios? check if you need the irst-driver (seems like it's a nvme drive) for the windows installation (maybe you need to load the driver so just put it in the usb folder).
      • magneh
        • Apr 2014
        • 591
        • Portugal
        Thanks for the reply.
        1.2V and 1.8V SSD are present
        Soldered seemed fine as NAND flowed into place nicely
        But to be sure, reballed it and resoldered it , same thing
        No drive appears in windows install
        • magneh
          • Apr 2014
          • 591
          • Portugal
          Hi
          thanks for the reply
          I see the internal storage and windows boot option but not sure that means the ssd is detected in bios
          dont see other tab where I can check this
          But also usb storage is present in the same list when not plugged in so...
          Ill investigate the drivers, but does not seem to be the issue IMHO
          • rediii
            h???, spurrrn
            • Mar 2018
            • 490
            Originally posted by magneh
            Hi
            check the drivers, it's a common problem with the irst mode and report pls
            • magneh
              • Apr 2014
              • 591
              • Portugal
              So ive tried with the drivers of this link
              https://www.intel.com/content/www/us...platforms.html
              Nothing
              • magneh
                • Apr 2014
                • 591
                • Portugal
                Got a message from the seller
                "The chip is brand new. It requires self programming"
                Can this be the case?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Can you see it with Diskpart ?
                  • zakin
                    • Jul 2013
                    • 5
                    • Moldova
                    Suggest you buy drive like this and reflow IC to your board as I did.
                    I mean Kioxia (Toshiba)
                    or Hynix
                    but you should make modifications according to schematic I've provided
                    • magneh
                      • Apr 2014
                      • 591
                      • Portugal
                      or Hynix
                      Very nice, thanks for the info.
                      I will get one Hinyx and change the resistor, if I can locate it.
                      Is there boardview available?
                      • zakin
                        • Jul 2013
                        • 5
                        • Moldova
                        Here you are
                        [MOD EDIT] Link to boardview https://www.badcaps.net/forum/troubl...matics-request
                        • yanhuachen
                          • Nov 2022
                          • 中国
                          surface pro5 and surface pro6 can only support NVME1.2, if you replace the hard disk with NVME1.3, the hard disk will not be recognized
                          • magneh
                            • Apr 2014
                            • 591
                            • Portugal
                            or Hynix
                            Thanks a lot Zakin
                            It worked fine after doing as you pointed out.
                            Hynix 256 GB installed with success.
                            Happy Surface again
                            • gnarendra2003@gmail.com
                              • Mar 2024
                              • india
                              please guide i have same problem
                              • chipsetrepair
                                • Nov 2014
                                • 24
                                • Philipines
                                Thanks a lot Zakin
                                Happy Surface again
                                Hey good morning, I have currently working with the same issue.
                                But I have questions to ask about the resistor part, could you explain bit about the process?
                                Mine was the samsung 256gb and then I bought the toshiba brand installed, then found out the ssd was short circuit
                                so upon researching I found out the if different brand the ssd resistor should be modified.
