a1278 green light with power not charging help
  • jheunne
    • Sep 2022
    • 62
    • philippines
    hi there i have a macbook pro a1278 which is not charging it has green light power no amber or charging. i already replace charging ic but still not charging. i know i have missed something. here i found out that the output voltage from the battery connector has 11v and drops to 0.47v
  • jheunne
    • Sep 2022
    • 62
    • philippines
    Re: a1278 green light with power not charging help
    here is the picture
    • mon2
      • 14369
      1) post or link the schematics for the logic board if on this forum.
      2) post the exact part number for your logic board. It should be of a 820-xxxx format.
      3) is the battery a known good battery? Often, the battery is the fault.
      4) locate the battery connector. Meter in dc volts mode. Measure the voltage of each pin to ground. Post each measurement. Attach the battery for these readings.
      • jheunne
        • Sep 2022
        • 62
        • philippines
        board id 820-2936 b
        j6950
        pin 9,8,7 = 14v drop to 0.47v
        while q7035
        pin 5 chgr phase shorted to pin 3,2,1 if it has parts
        • mon2
          • 14369
          Post the other voltages on the battery connector.
          Do not attach the battery yet. Use only the power adapter.
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • nhe quan
            MacBook Air A2681 M2 not power on , only green light of webcam
            by nhe quan
            Hello every one, i have bought macbook air M2 but not power on,
            try shift + option + control + power -> the webcam green light is on but not thing happen.
            anyone have ideas of this ?
            08-26-2025, 02:00 AM
          • JasonC89
            Macbook Pro A1502 820-4924-A - No Power/Charging Light
            by JasonC89
            So Ive got a Macbook Pro here with no power or charging light.
            I have taken the board out and did an inspection and found a small bit of water damage on C1267 (PP1V05_S0). Cap fell off as I cleaned the area but I dont think this is responsible for my no power or light issue, and should probably work just fine without it.
            So after watching a few Louis Rossman videos and some post here with similar issues, Ive done a lot of testing and have found the following values of the main lines I think are important:
            PPDCIN_G3H = 16.63V
            PP18V5_DCIN_FUSE = 16.63V...
            11-11-2024, 12:14 PM
          • franjr
            MacBook pro A1278 (820-3115-B) green light no power on
            by franjr
            Hi, I have a MacBook pro A1278 (820-3115-B) that has green light on the charger and does not turn on, the fan does not spin.
            The voltages in the SMC seem correct. I have made voltages measurements on the main coils and I put their measurements here:
            L7220..........3.3V
            L7260...........5.12V
            L7330..........1.5V
            L7030..........12.67V
            L3895..........2.5V
            L7760..........1.80V
            L9701..........0V
            In the following coils they give me continuity with ground, which seems strange to me:
            L7550,L7510,L7520........ 0V
            01-30-2023, 04:24 PM
          • mon2
            A1278 820-2530-A Green Light, No power
            by mon2
            Hi. Troubleshooting a macbook A1278 logic board that was working but owner was complaining about random turn off during use issues.
            Now the logic board will not power on for the fan spin.
            Magsafe power adapter is fine @ 16.x volts; green light on adapter is lit (always).
            If the battery is docked, see the 3v42 rail ok. Remove battery, power adapter yields the same working 3v42 rail.
            Have not checked all of the power rails but PPBUS_G3H is active @ 12v6.
            The concerning rail (reviewing this one now) is that PPVCORE_S0_CPU_REG...
            12-29-2020, 11:34 AM
