A1278 820-2530-A Green Light, No power
  • mon2
    • 14370
    Hi. Troubleshooting a macbook A1278 logic board that was working but owner was complaining about random turn off during use issues.
    Now the logic board will not power on for the fan spin.
    Magsafe power adapter is fine @ 16.x volts; green light on adapter is lit (always).
    If the battery is docked, see the 3v42 rail ok. Remove battery, power adapter yields the same working 3v42 rail.
    Have not checked all of the power rails but PPBUS_G3H is active @ 12v6.
    The concerning rail (reviewing this one now) is that PPVCORE_S0_CPU_REG is @ 0 volts.
    Could the SMC be defective?
    Does the SMC actually contain firmware?
    Using boardview, lit up the PPVCORE_S0_CPU rail and removed all related caps (tantalums and ceramics). Still no power on this rail.
    The resistance (red on ground); black on PPVCORE_S0_CPU is @ 8.x ohms which sounds very low.
    The PM_SLP_S4_L line is low. Believe this line is required to be HIGH to enable the mosfet @ Q7813 to enable the left half of the dual regulator U7200? The right half of the regulator is enabled and working fine.
    Any suggestions on how to debug this logic board?
    From our understanding, if all is well, the fan should spin and do so even without a power on button press? That is what we see on the youtube videos.
    Thanks.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: A1278 820-2530-A Green Light, No power
    Core 2 MacBooks with NVidia MCP need the power button to be triggered in order to turn on.
    As always go through the list of power rails and measure voltages when triggering power button.
    • mon2
      • 14370
      Merci Piernov. After applying the keyboard flex cable again, the motherboard indeed works fine. Very embarrassed by this ghost chase as we removed SMD caps (ceramics and tantalums) in effort to remove the low resistance of the S0_CPU rail. In the end, there was no such issue to be repaired. Just watched too many youtube videos where none showed the use of a power switch. Weird.
      Thanks again!
      • jheunne
        a1278 820-2936a fan spin green light only help
        by jheunne
        hi there i have a macbook pro a1278 board 820-2936a no boot no dispaly only fan spin and green light. i seen some corroision on top starting to u4900 to u3890 i manage to clean it but still no luck to boot. i figure out that in pp15v t29 there is no available out voltage it shows only 0.6 volts only...
        10-24-2024, 04:19 AM
      • Arshad alam4659
        a1278 no green light
        by Arshad alam4659
        i have a a1278 820-3115-b with no green light some measure volt
        PPBUS_G3H=12v
        PP3V42_G3H=3.43v
        SMC_BC_ACOK=3v
        SMC_BC_ACOK_VCC=3.4v
        SYS_ONEWIRE=3.46v
        ADAPTER_SENSE=3.42v
        someone help i try with original charger
        09-26-2024, 08:21 AM
      • MOSSEP
        Monitor Audio RSW12 - Green light, but no sound
        by MOSSEP
        Hi
        Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
        Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
        The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
        I have already tried replacing all of the...
        01-26-2025, 08:33 AM
      • MOSSEP
        Monitor Audio RSW12 - Green light but no audio
        by MOSSEP
        Hi
        01-26-2025, 08:18 AM
      • franjr
        MacBook pro A1278 (820-3115-B) green light no power on
        by franjr
        Hi, I have a MacBook pro A1278 (820-3115-B) that has green light on the charger and does not turn on, the fan does not spin.
        The voltages in the SMC seem correct. I have made voltages measurements on the main coils and I put their measurements here:
        L7220..........3.3V
        L7260...........5.12V
        L7330..........1.5V
        L7030..........12.67V
        L3895..........2.5V
        L7760..........1.80V
        L9701..........0V
        In the following coils they give me continuity with ground, which seems strange to me:
        L7550,L7510,L7520........ 0V
        01-30-2023, 04:24 PM
