Lenovo nm-b321 v1. 0 shutdown problem
  • ahmarzo
    • Mar 2015
    • 171
    • india
    Have lenovo nm-b321 motherboard it shutsdown after 1 min 10 seconds everytime. Have flashed the bios from official site and flashed ec bios also but same problem. Have checked with or without hard disk. What is the problem please help have checked without the keyboard also.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo nm-b321 v1. 0 shutdown problem
    Try changing the flash drive. make sure its listed in the bios. It could be a thermal event.
    • tomodachi
      • Apr 2012
      • 603
      • Turkey
      does it work normal without battery ?
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • s_specialist
        Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
        by s_specialist
        Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
        07-07-2025, 11:47 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
      • c.daniel
        Lenovo V310-15IKB weird bios problem...
        by c.daniel
        Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
        sn LR09493E
        MB DAOLV6MB6F0 REV. F
        The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
        Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
        Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
        08-22-2025, 05:39 AM
      • konradx
        Lenovo Thinkpad T15 Touchscreen problem bios
        by konradx
        i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
        That is my DUMP.
        My device:
        SN: PF29Y4N6
        1s20S7S2WF00PF29Y4N6
        MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
        09-06-2024, 01:33 AM
