Huawei MediaPad T3 won't charge
  • eniac22
    • 124
    • Greece
    Huawei MediaPad T3(AGS-W09) don't charge because has a broken usb port. I have replace the port but now is charge only when the tablet is off and with low Amp draw, about 0.45A
    The diode on the picture its broken, where can find a replacement? Anyone knows the specs of this component ?
  • mon2
    • Dec 2019
    • 14261
    Re: Huawei MediaPad T3 won't charge
    Read off the topside markings of the diode - the other one beside it looks to be the same.
    • eniac22
      • 124
      • Greece
      I take new photos
      • mon2
        • Dec 2019
        • 14261
        My educated guess is that this is a TVS diode protecting the D+ / D- pins of the USB 2.0 connector. The flat 4 pad device in front of these 2 x Q7 diodes is the EMI filter.
        That is, for quick testing, remove this part and test again. Noting that a transient will NOT be suppressed if one exists on your external USB connected device.
        Confirm the operation and then can proceed to replace it.
        • eniac22
          • 124
          • Greece
          You have right this diode is connected to D+ / D- pins so can't be related with my problem
          • mon2
            • Dec 2019
            • 14261
            The older chargers do use the usb d+ and d- lines to negotiate the voltage and current to charge the battery.
            Remove this defective diode and test again.
            See here to learn about BC1.2
            https://training.ti.com/what-is-usb-bc-12
            • eniac22
              • 124
              • Greece
              I removed the diode, tablet is Amp draw about 0.45A if is OFF and 0,08A when is ON.
              Do you know with what diode can replace the faulty diode?
              • ipatch
                troubleshooting microsoft surface pro 4 no power no led charge light
                by ipatch
                hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                10-05-2023, 11:59 AM
              • ruletero
                Acer a515-43 low battery charge voltage
                by ruletero
                Hi
                Acer A515-43
                LA-H801P
                Fail: Does not charge battery, has low voltaje on connector.
                Laptop didn't want to turn on, only charge led blinked.
                I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                10-24-2022, 02:31 PM
                Huawei MateBook 16s Notebook 16s Specification for Upgrade or Repair
                This specification for the Huawei MateBook 16s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16s boardview and 16s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Huawei MateBook 16s...
                09-07-2024, 07:12 AM
                09-07-2024, 06:31 AM
                09-07-2024, 06:21 AM
