Understand super I/O chip numbering
  • Sryii
    • May 2014
    • 22
    TLDR: which lines on the naming of super Io chips are critical for finding a replacement?
    I have a Lenovo Yoga 2 Pro that isn't turning on. The plug was damaged and it looks like that led to something on the board dying. When plugged in the charging light is solid amber but it will never turn on. After my VERY newbish attempts to user a multimeter I was able to determine that the power was at least starting out the right way and the MOSFETs were working, there was a drop in charge when the power button is pressed on that line and ultimately the super io chip got insanely hot. Looks like it has a scorch mark on it.
    This is a personal laptop and I wanted to take a stab at saving it, but it is hard to find a replacement board that I know will work and isn't a couple hundred bucks. I thought I might try my hands at replacing the chip. Problem is I can't find the exact number written on the chip online so I'm curious if the banking scheme includes a bunch of other identifiers and if just the first line of the name is important.
    The full ITE chip is
    IT8586VG
    1402-FXO
    SCOR3A(not sure about the last number)
    I've seen several online with the first line but not the last two lines. Any insight on this would be much appreciated. Thank you for reading.
  • mon2
    • 14415
    Re: Understand super I/O chip numbering
    Use
    IT8586VG FXO
    1402 = 2014, week #2 (manufacturing date code) so will vary with the chip.
    3rd line is some format that only twins will understand.
    Here is one supplier:
    https://www.ebay.ca/itm/1pcs-LENOVO-...-127632-2357-0
    There are others on AliExpress.
    • Sryii
      • May 2014
      • 22
      Thank you @mon2! So helpful! I was curious if that was the case.
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • ongobongo
        Asus ROG Ally - Super IO Chip replacement
        by ongobongo
        anyone here who has experience with replacing the super IO chip of an ROG ally?
        I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
        Ongo
        11-17-2024, 11:27 AM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • chickenhawk88
        Preflash Super IO chip
        by chickenhawk88
        I was wondering if you guys know anyone that sells Super IO chip ITE IT8390-256 flashed with your specific laptop. Im debating to see if this available out there vs buying chip and programmer myself. Right now the chip plus programmer is about $60. But i still need the file that goes on chip. The laptop is RAZER BLADE 15 RZ09-0369.
        05-19-2024, 01:22 PM
