acer aspire a515-51g c5v01 no power
  • funybux
    Akila-D
    • Sep 2022
    • 13
    • Malaysia
    hi everyone!,
    I'm looking for help to repair this motherboard, I followed a few threads and many youtube videos but still, I cannot figure it out
    Reason: Liquid Damage
    Model: acer aspire a515-51g
    Motherboard: C5V01 LA-E892P REV: 1A
    I already make some tests:
    ON/OFFBTN 3.2V OK
    EC_ON 3.17V
    SPOK 2.15mV
    SOC_RTCRST 3.006V
    PL401/402 no power
    PQ403 19.6V
    PU401 PIN
    6 - 0.03mV
    7 - 1.16mV
    8 - 0.11mV
    9 - 4.6V
    10 - 0.05mV
    11 - NO POWER
    EN 0.03mV
    RB 0.03mV
    DB1 (chip side(left)) 7.55mV, right 0.06mV
    I need your help.
    Thanks in advance.
  • funybux
    Akila-D
    • Sep 2022
    • 13
    • Malaysia
    Re: acer aspire a515-51g c5v01 no power
    sorry forgot to mention.
    after the motherboard is damaged, the power led is on and the fan spins one time then it stops and near the GPU this marked area, both r22 coils are heated. A few times this happened now no power
    • funybux
      Akila-D
      • Sep 2022
      • 13
      • Malaysia
      hi, Does anyone have a solution or idea?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        3V_EN_R Present?? PQ302/303 voltage on Pin1/4/8??
        • funybux
          Akila-D
          • Sep 2022
          • 13
          • Malaysia
          Hi, thank you for your response
          3V_EN_R 0.02mV
          PQ302 PIN
          1 - 19.6V
          4 - 25.59V
          8 - 19.6V
          PQ303 PIN
          1 - 19.6V
          4 - 25.59V
          8 - 19.6V
          • Sephir0th
            • Oct 2020
            • 1282
            Probably multiple issue to solve. I'd need a overview about voltages (nothing except 19V and 3V LDO present) and especially resistances of each power rail. Check at least the coils.
            Otherwise iirc on this board 3.3V and 5V come up only after power press. So first thing you should do is to check whether the power button does indeed still work as expected.
            FairRepair on YouTube
            • funybux
              Akila-D
              • Sep 2022
              • 13
              • Malaysia
              "Probably multiple issue to solve"
              power button is working. before press 3.3v, after press 0v
              • funybux
                Akila-D
                • Sep 2022
                • 13
                • Malaysia
                hi I appreciate your time,
                if i update voltages on these pins PU301, PU501, PU401, is it enough for checking?
                resistance to ground 474.1k
                and sorry actually i don't know how to check the resistances of each power rail. i can check component resistances but have no idea how to check on rails. can you guide me to check that?
                • mon2
                  • Dec 2019
                  • 14271
                  Remove all power / no battery.
                  Meter in resistance mode.
                  Place one meter probe onto one side of the inductor / coil. Other meter probe to ground. Record the measurement and meter scale used for the test.
                  If the resistance is very low, the local power rail may be shorting due to a defective capacitor or another component.
                  Each coil / inductor is linked to a local power supply rail.
                  If your meter shows a '1' or 'OL' then switch to a higher resistance scale on your meter till you can measure a proper resistance value.
                  • funybux
                    Akila-D
                    • Sep 2022
                    • 13
                    • Malaysia
                    hi mon2, i appreciate your support and guidance
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Resistance on 3V LDO??
                      • funybux
                        Akila-D
                        • Sep 2022
                        • 13
                        • Malaysia
                        hi, please check the attachment, im not sure i measured correctly.
                        • funybux
                          Akila-D
                          • Sep 2022
                          • 13
                          • Malaysia
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Measure resistance og +3v LDO directly on PU401(PC401). Is 3v present there?? If present, remove DB1 & RB17. Now check again whether you get 3v_En_R on pin1 of RB16
                            • funybux
                              Akila-D
                              • Sep 2022
                              • 13
                              • Malaysia
                              resistance - ldo3 25.27k
                              Is 3v present there? yes
                              removed DB1 & RB17 but still 3v_En_R 0v
                              • funybux
                                Akila-D
                                • Sep 2022
                                • 13
                                • Malaysia
                                any help
                                • mon2
                                  • Dec 2019
                                  • 14271
                                  3v_En_R is driven by KB9022. Confirm that UB1 is being powered.
                                  • funybux
                                    Akila-D
                                    • Sep 2022
                                    • 13
                                    • Malaysia
                                    thank you for the response.
                                    ub1 has power but +3VLP_EC is showing 0.0054v
                                    • mon2
                                      • Dec 2019
                                      • 14271
                                      Very good. LB1 must be defective. Can you check the voltage on both sides of LB1 inductor ?
                                      This not a critical part and if required, can be bridged with a piece of wire (after power is removed of course) for testing.
                                      Update:
                                      My power path flow may be in error but you are on the proper track.
                                      The +3VLP_EC has to receive power to power the GPIO pins on VCC_IO2 bank. If this rail is 0 volts, then the batch of GPIO pins on UB1 will not be powered.
                                      See attached.
                                      • phonesafept
                                        • Mar 2023
                                        • 3
                                        • Portugal
                                        Hi, this issue was solved, i have exactly the same problem, with the same model!
                                        Thank you
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                        • DenK
                                          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                          by DenK
                                          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                          12-06-2024, 01:29 AM
                                        • Bonaventure Vigil
                                          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                          by Bonaventure Vigil
                                          Dear All,
                                          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                          12-12-2024, 10:22 AM
