Hp G37A UMA PROBLEM
  • Mcfalsi
    • Apr 2015
    • 191
    • Türkey
    Hp G37A UMA PROBLEM
    Hi
    Mb DAG37AMB8D0 REV D
    Since the external video card is problematic, I disabled it, when I install the intel display dirver, it stays on the black screen, windows does not open, why? has anyone encountered such a secret before?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp G37A UMA PROBLEM
    Display comes on internal screen as long as intel driver is not installed?? Right??
    If so, its related to SOC. Look carefully around SOC for corroded caps.
    • Mcfalsi
      • Apr 2015
      • 191
      • Türkey
      Since the external video card is problematic, I did the um operation. I just installed the intel video card driver, and the screen goes black, the black screen remains, when I turn it on and off, windows starts, then when I open it in safe mode, the black screen appears.
      Bad english soryy
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        So you mean black screen in safe mode also?? Can you remove the display driver in safe mode??
        Btw, the intel driver you installed was from hp site or with driverpack or similar stuff??
        • Mcfalsi
          • Apr 2015
          • 191
          • Türkey
          No, there is an image in safe mode because the driver is disabled, but when normal windows starts, the screen remains black and blank after the logo. I can't get an external hdmi image. There is an image when the driver is disabled. The driver was downloaded from hp support site, I downloaded it from intel dedtek site and tried it, the result is the same
          • Mcfalsi
            • Apr 2015
            • 191
            • Türkey
            please help uma bios need
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              This is certainly not a bios issue.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
