ASUS UM425 power on, but no screen
  • Lazycat
    • Jan 2022
    • 7
    • Taiwan
    Hello sir,
    my laptop can be power on, but the screen doesnt post.
    I use flir camera ,then I see 3 ,then I see 3 components are overheated。
    I think it may be the reason。
    THANKS A LOT
  • mon2
    • 14002
    Re: ASUS UM425 power on, but no screen
    Hi.
    1) Asus is in your backyard Give them h*ll for not sharing the schematics for their logic boards. Miss my travels to Taipei, Mr. Brown Coffee and Taitronics.
    2) the first picture of the hot capacitor is of concern. The others are power inductors to support high current switching regulators which will be normally hot in operation.
    3) place your meter in dc volts mode. With great caution, measure the voltage to ground of each inductor. Each inductor will be linked to a local switching buck regulator ( accepts a high voltage as input, will output a low voltage as output ). Checking to be sure that each regulator is working with a good voltage.
    Red meter on the coil leg, black to ground (shield is ok).
    Post your measurements of the voltages.
    4) on the cap that is very hot, what are the smd markings from the top side of the IC? From your details, we can find a datasheet and determine which capacitor is likely on your logic board.
    Post a closer pic of this area of the logic board so we can know which pin of the IC mates with the capacitor.
    5) what is the history of the logic board? Any liquid spills? Just failed one day?
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • ShadowAi
      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
      by ShadowAi
      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
      03-15-2024, 10:46 AM
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
    • Themonster
      Laptop Asus Strix G15 power up, but always black screen
      by Themonster
      Hi im Monster ("nickname"), i will explain what happens with this laptop pc:
      Asus Rog Strix G15 : model = G512LW
      The screen is not broken, almost not physically.
      When i power up the computer this run perfect but nothing show in screen, also in HDMI port.
      More or less 10 sec later, when win 11 is loaded , HDMI show things i mean user login in win 11.
      Original or main screen doesn't works, anytime, but HDMI works fine when win11 load nicely.
      When win11 is loaded , i check device administrator, and i found a system firmware error, so what...
      01-19-2024, 04:00 PM
    • Thomas Smith
      Asus Tuf gaming fx506l no power, mosfet does not open
      by Thomas Smith
      Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
      Initial Symptoms:
      • The laptop has no power at all (no LEDs, no fan spin).
      • No 3.3V or 5V present on the board.
      • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
      Power Rail Checks:
      1. Charger input (FETs PKCH2BB)
        • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
      2. BQ24780S Charger IC:
        • VCC and ACDET are present.
        • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
        • Shunt resistor has 10Ω to ground.
      03-30-2025, 03:38 AM
