versus v_book 14slvv3
  • roixijram
    • May 2019
    • 50
    • tunisia
    Can you help the audio driver for this device?
  • bohaboha
    how to install gl usb2.0 uvc camera device driver on windows 10
    by bohaboha
    Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
    but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
    any help?
    01-26-2025, 08:33 PM
  • charif
    Audio Driver for Thomson P14C4BK128
    by charif
    Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
    I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
    The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
    Here are the details:
    • Model: Thomson P14C4BK128
    • Operating System: Windows 10 64-bit
    If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
    Thanks in advance for your help!
    04-30-2025, 05:41 PM
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • Piaskos
    Dell Vostro 5490 - no sound, no audio device
    by Piaskos
    Hi, i've got problem with Dell Vostro 5490.
    Board - Mantis CML 18788-1
    Windows says "no audio device detected". The other functions work properly.
    What i've done:
    1. I checked motherboard
    2. I changed audio codec (ALC3204)
    3. I reflashed bios with clear ME
    4. Audio is enable in bios
    5. Both speakers are good
    6. After installing the drivers from the Dell website, the devices visible in the manager:
    - Audio for intel displays
    - Intel Smart Sound Technology...
    01-30-2023, 02:58 AM
  • Phil289
    Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
    by Phil289
    Hi
    Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
    Is there any reasons why they shouldn't be used?
    I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
    If I can't find any Panasonic what would be any other good makes to consider?
    Thanks 🙂
    09-25-2022, 03:02 PM
