Acer Aspire ES1-431 no Power LED
  • noipi
    • Aug 2017
    • 69
    • Singapore
    I have an Acer Aspire ES1-431 Laptop, actually the normal behavior is whenever we turn on the acer es1-431 it must have Power LED should remain turned on (Blue)after pressing the power botton. However, after I received the laptop, the Power LED does not turn on, but the laptop is working fine. So I opened the laptop, and trace the LED with the DAZ8ADMB6D0 code schematic.
    The 3v are present when i turn on the unit, and the resistors are good, the LED light of both PWR/Battery parts are fine.
    any idea why there is no PWR led(BLUE) even the battery led no light(amber LED)
  • mon2
    • Dec 2019
    • 14157
    Re: Acer Aspire ES1-431 no Power LED
    hi. You are saying that the PWR dual color LED is not defective but the BLUE / AMBER does not light up ?
    The signals are linked to the IT8987 (U8) and driven by its GPIO pins.
    The # suffix on the signal names = ACTIVE LOW. So if the signal is 0v (as an example); the led should be ON.
    Check the voltage @ R313, both sides of the resistor against ground.
    meter in DC volts (5v or higher is ok); red meter probe @ R313 & black meter probe to ground. What is the voltage reading ?
    Then repeat for R312.
    If U8 is not pulling this line LOW, the LED will not enable. Not familiar with the ITE chip operation but you can try a fresh BIOS upgrade which may reflash the firmware inside this controller and then test again.
    • noipi
      • Aug 2017
      • 69
      • Singapore
      Thank you for the very fast reply.
      i measure the voltages of the resistors and the result is here in the picture that attached. i will next to flash the bios, while im preparing my tools for it. I just post the result of the voltages.
      sorry for the pic, im just using a low resolution cellphone, and also for my english, i'm Asian.
      thank you bro.
      • mon2
        • Dec 2019
        • 14157
        Remove all power. Place your meter into DIODE mode.
        Place one meter probe directly onto pin #1 of the dual color led.
        Place other meter probe directly onto pin #3 of the dual color led.
        Can you see the LED light up? If not, reverse the meter probes.
        Then repeat using pin #4 of the dual color led. This is only to confirm that both LEDs are ok.
        • noipi
          • Aug 2017
          • 69
          • Singapore
          hi Mon2, yes it lights up when i test it in diode mode, lights up red and blue when test it with the probe.
          Its very interesting problem, but the owner now wants to use it, even though without blue ON led on it.
          Sadly, Now i need to re-assemble the acer es1-431 and give it back to the owner, he will return it next week after school weekend. Then i will update again sir mon2 after i flashed the bios. Maybe it needs to be updated, but if not, there might be a problem somewhere, or the IT8987 (U8) malfunction?
          Thank you for your time, hope next week will update again.
          • mon2
            • Dec 2019
            • 14157
            Yes, appears that U8 is not enabling the respective LEDs.
            As a work around, you can hard wire the BLUE led circuit by:
            a) carefully removing the resistor and rotating so that one leg is towards the LED; the other side of the resistor is floating on the PCB or just sitting on the green solder mask (acts like an insulator so it is safe to do)
            b) then with a quick use of the soldering iron, attach a thin wire (wire wrap wire is good) onto the floating side of the resistor and then ground this new wire
            You are basically hard wiring the BLUE led to be always ON when there is power to the board.
              ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
              This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
              09-12-2024, 03:28 PM
              ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
              This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
              This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              09-06-2024, 05:27 AM
            • DenK
              Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
              by DenK
              Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
              1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
              12-06-2024, 01:29 AM
            • Bonaventure Vigil
              ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
              by Bonaventure Vigil
              Dear All,
              Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
              At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
              12-12-2024, 10:22 AM
