Unsoldering Dell latitude 5400 bios chip
  • cbake886
    • Jun 2021
    I have unsoldered bios chip in the past but the one on this Dell latitude 5400 will not come off. I have tried heating it from below, from the top with a heat gun and no luck. I messed up the chip and now I need to replace. I have replacements but I still cannot get it off. Any pointers?
    Pics:
    https://imgur.com/a/sYZnOXX
  • mon2
    • 14672
    Re: Unsoldering Dell latitude 5400 bios chip
    These are multilayer PCBs and with lots of ground plane. The ground plane acts like a heat sink. Respectively you will need a high temp hot air station. Ours claims to reach 550C (BEST 863 which we understand to be a clone of the Quick series). Even the original is not too crazy on pricing but we paid ~$200-$250 USD from Aliexpress. We have met with BEST TOOLS in HK at past electronic trade fairs. They are a solid vendor and manufacturer who has stated they will sell us spare parts if we ever need to service our unit. So far, 2 years later, still very pleased with this station.
    We did face an Asus motherboard that was like your case - the IC would not budge. While the client opted to replace the entire logic board, @SMDFlea and others suggested that we were missing the underside heater. Since then, we have sourced a Hakko heater to help the heat to travel from under the PCB. There are some nice IR tables for cheap on Aliexpress that may be worth a review for these type of boards.
    The combination of the hot air from the TOP while the heater from the bottom side (IR or other) will do the trick. Finally, you must, repeat must apply flux onto the part that is being removed / reflowed or soldered. Flux just makes life easier. Amtech is the name being thrown around but TBH, we have yet to see the 'real Amtech flux'. Ours is from Aliexpress but it works fine. You are in MI (our neighbor across the pond - miss my La Shish & Mexican Town food) - you should be able to source from Louis. The pricing we saw on Amazon for the same is just silly high for flux.
    • jhanra
      by jhanra
      11-02-2024, 04:19 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • chaos_prevails
      Dell Latitude E7470 i7: no TPM + TXT in BIOS/Firmware (but chip is present on the motherboard)
      by chaos_prevails
      I've purchased 2nd hand Dell Latitude E7470 i7-6600U and it works fine, except ... there are no TPM or TXT/Trusted Execution settings in the BIOS/Firmware. However, looking at the schematics I found the chip handling TPM (NPCT650JA0YX) soldered to the system board. Also, looking at the service tag and the product specifications, this device comes with TPM (and vPro) support (I know that devices sold in China, Russia are not allowed to ship with TPM but this should be reflected in the service tag). I can also login to MBex to configure, etc.
      In the produce specs...
      02-12-2024, 05:21 AM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
