hp elitebook 840 g3 battery present but not charging
  • karim011
    • Nov 2016
    • 122
    • Morocco
    problem battery present but not charging. I tried to replacing 3 batteries and chargers but without result. Pls you help.
  • mon2
    • 14672
    Re: hp elitebook 840 g3 battery present but not charging
    Hi. If someone has this schematic or BV file - they will post to your other thread in the schematic requests. Just checked my database and could not locate one.
    While waiting...
    1) review where the power adapter enters the board -> you should see 2 x DCin mosfets (8 pin part).
    2) near the DCin mosfets will be the charger IC. The charger IC controls the DCin mosfets as well as 1 x battery mosfet and 2 x battery charge mosfets (to dial up the voltage to charge the battery pack).
    Read off the markings from the charger IC -> or post clear pictures of this device. We need to know the markings so we can review example schematics to learn about your laptop.
    • karim011
      • Nov 2016
      • 122
      • Morocco
      ok. thank u so much for replay
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        What is board number ?
        • mon2
          • 14672
          6050a2892401-mb- a01
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Is not available i think
            • app82
              • Aug 2022
              • indonesia
              Another schematic or chip datasheet may help. Sometimes dead mosfet causing this problem if there is internal chargepump of the chip failed to turn another mosfet on, because the dead mosfet short it.
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                Did you already replace the second mosfet? Check if battery is recognised in bios. Which charging ic you have on your board.
