X1 Extreme gen 1 20MF GTX 1050ti code 43 in device manager
  • gm20
    • Sep 2022
    • 7
    • Poland
    I have a laptop as in the title. It's working pretty normally except discrete GPU and HDMI port.
    GPU failure happened during normal work (light load, browser only), no liquid damage.
    I checked resistance and voltages on coils and only one looks suspicious to me. I mean this with 4ohm and 0V, I don't know what is the purpose of this coil (I don't have schematics).
    What else I should check?
  • gm20
    • Sep 2022
    • 7
    • Poland
    Re: X1 Extreme gen 1 20MF GTX 1050ti code 43 in device manager
    Another measurements:
    Vcore 0.7ohm, constant 0.8V
    Vmem: 140ohm, constant 1.35V
    • gm20
      • Sep 2022
      • 7
      • Poland
      I found schematics for this board -> google "wistron lpm 1".
      The missing voltage on coil PL9001 is needed for VCCGFXCORE_I. I must find a reason why VCCGFXCORE_I is 0V
      • piernov
        • Jan 2016
        • 4435
        • France
        https://logi.wiki/index.php/User:Pie..._I_solve_it.3F
        • gm20
          • Sep 2022
          • 7
          • Poland
          VCCGFXCORE_I is for Intel Graphics it's 0V because its not heavy used on Windows desktop. After a run Furmark on UHD 630 I see 0.9V on PL9001 coil, so its everything ok.
          Summarizing, I have proper volatages on all power rails, resistance is also ok. But GTX 1050ti max q does't work, error code 43 in device manager.
          I exclude software problems (tested on windows 11 and ubuntu, both with clean install).
          I exclude firmware problems (installed newest bios from lenovo and other firmware like intel me).
          So what options do I have? Dead GPU?
          • gm20
            • Sep 2022
            • 7
            • Poland
            On idle laptop draws 30 watts - unusable on battery. So I decided to turn off faulty GTX 1050. I located GPU_PWR_EN on U3802 element and I cut 4th leg (GPU_PWR_EN_D). After this on idle laptop draws 4-7 watts (over 16 hours on battery). No more NVIDIA in device manager and no more code 43.
            • Sephir0th
              • Oct 2020
              • 1282
              I think you missed some coils related to the GPU, so we have less than the "half picture" to work with in front of us. At least VMEM, maybe PEX, maybe CORE_S, something like that. Probably underneath the black tape/foil, but missing. Since it's a GPU issue, probably important to check. Just saying.
              FairRepair on YouTube
              • gm20
                • Sep 2022
                • 7
                • Poland
                You're quite right I missed some rails. I watched only a few Louis Rossmann videos on youtube, so I'm not an expert.
                After your suggestion, I searched again and I located the PEX rail - a very small element with a tiny coil (looks like a capacitor).
                PEX_PWRGD 200 ohms and constant 1V
                VCCGFXCORE_D 0.7 ohms and constant 0.8V (three coils and three DrMOS)
                DGFX_PHASE1 PLA302 (coil) PUA302 (DrMOS) 0.8V 0.7 ohms
                DGFX_PHASE2 PLA304 (coil) PUA303 (DrMOS) 0.8V 0.7 ohms
                DGFX_PHASE3 PLA306 (coil) PUA301 (DrMOS) 0.8V 0.7 ohms
                VCC1R35VIDEO PLA401 (coil) PUA401 1.35.V 140 ohm
                PEX exists, VRAM exists, VCCGFX exist. What else is needed for GPU work?
                • redoxy
                  • Sep 2018
                  • 100
                  @gm20
                  Did you manage to solve this issue?
                  Interested in how this was addressed.
                  • Shone77
                    by Shone77
                    Hello friend,
                    Any chance for bios dump. I have the same model but only black screen.
                    09-21-2022, 08:13 AM
                    LCD LED TV Service Menu Codes
                    ALL LCD LED TV SERVICE MENU CODES
                    Service Menu Code with Board Name
                    China Universal Board / Jumper Board Service Menu Code
                    Changhong Ruba Service Menu Code
                    Ecostar LED TV Service Menu Code
                    Orient LED TV Service Menu Code
                    Haier LED TV Service Menu Code
                    TCL LED TV Service Menu Code
                    Samsung LED TV Service Menu Code
                    LG LED TV Service Menu Code
                    Videocon LED TV Service Menu Code
                    Supra LED TV Service Menu Code
                    Toshiba LED TV Service Menu Code
                    Symphony LED TV Service Menu Code
                    Veste/ LED TV Service Menu Code...
                    10-31-2024, 03:58 AM
                  • Sorrow1
                    Intergraph TDZ 2000 mainboard post code 2F/2E
                    by Sorrow1
                    I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                    It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                    When I recorded video of POST card and played it in slow...
                    01-03-2024, 04:13 AM
                  • DynaxSC
                    MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                    by DynaxSC
                    Hi Folks
                    I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                    Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                    09-29-2024, 04:27 PM
                    Gigabyte Sabre 17-1050Ti-802 Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte Sabre 17-1050Ti-802 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17-1050Ti-802 boardview and 17-1050Ti-802 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 11:44 AM
