Board Model is DA0ZRWMB6GO REV:G and I found 19V on PQ22 and Gate has no voltage. Is that mosfet problem? Sorry for my bad english.
					Acer E5-574G No power, No Charging help needed
 Re: Acer E5-574G No power, No Charging help needed
 Pin 4 - 0.06 - 0.09V
 Pin 6 - 2.64V
 Pin 14 - 0.39V
 Pin 17 - 0.14V
 Pin 18 - 0.06V
 Pin 19 - 0.14V
 Pin 20 - 0.14V
 Pin 24 - 6.06V
 Pin 25 - 5.74V
 Pin 26 - 0.14V
 Pin 27 - 0.14V
 Pin 28 - 19.31V
 And the rests are 0VComment
 PQ22 is probably defective but confirm it with resistance checks.
 Remove all power. Meter in resistance mode.
 Check the resistance across the mosfet:
 Source (1-2-3) and drain (5-6-7-8)
 Source and gate (4)
 Gate and drain
 Post each measurement. If the resistance is low, the mosfet is defective.
 PQ22 is a very typical mosfet and can be replaced with many others.Comment
 Sorry for my late response ;PQ22 is probably defective but confirm it with resistance checks.
 Source and gate (4)
 Gate and drain
 Source and Gate - 4.35 MΩ
 Source and Drain - 00.85 MΩComment
 If there is no unexpected Short around PU5 you should proceed with replacing it (PU5).Comment
			by abrahim110🧵 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
 I have an Acer Aspire 5 A517-52G-53NB laptop.
 The onboard (soldered) RAM was faulty, so I physically removed the chip.
 I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8 GB DDR4 SO-DIMM installed.
 ✅ System status:- BIOS mod is done (SPD removed)
- Laptop boots to Windows normally
- RAM is detected and stable
 ❌ Problem:
 The battery is not charging:- Power adapter
			I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
 report is also good for battery.
 Following https://www.badcaps.net/forum/troubl...arging-circuit,- DCIN/VCC: 19.1
- ACIN/ACDET: 3v
- REGN/VDD: 6v
- CMSRC : 19v
- ACOK: 3.3v
- ACDRV: it is 19v, not 25V(when charging, the ACDRV
			by CPUFiddlerHi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
 This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
 I've downloaded...1 Photo
			by titomno2Hi guys,
 I currently trying to figure out why the laptop of my friend did not charge.
 It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
 At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
 I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
 My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...1 Photo
			by titomno2Hi guys,
 My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...06-11-2024, 02:54 AM
- Loading...
