Acer E5-574G No power, No Charging help needed
  • KoPhyoe
    • Jul 2021
    • 24
    • Myanmar
    Board Model is DA0ZRWMB6GO REV:G and I found 19V on PQ22 and Gate has no voltage. Is that mosfet problem? Sorry for my bad english.
  • mon2
    • 14663
    Re: Acer E5-574G No power, No Charging help needed
    Start with carefully checking the voltages on each pin of charger IC at PU5 (BQ24780SRUYR). Post your measurements.
    • KoPhyoe
      • Jul 2021
      • 24
      • Myanmar
      Pin 4 - 0.06 - 0.09V
      Pin 6 - 2.64V
      Pin 14 - 0.39V
      Pin 17 - 0.14V
      Pin 18 - 0.06V
      Pin 19 - 0.14V
      Pin 20 - 0.14V
      Pin 24 - 6.06V
      Pin 25 - 5.74V
      Pin 26 - 0.14V
      Pin 27 - 0.14V
      Pin 28 - 19.31V
      And the rests are 0V
      • mon2
        • 14663
        PQ22 is probably defective but confirm it with resistance checks.
        Remove all power. Meter in resistance mode.
        Check the resistance across the mosfet:
        Source (1-2-3) and drain (5-6-7-8)
        Source and gate (4)
        Gate and drain
        Post each measurement. If the resistance is low, the mosfet is defective.
        PQ22 is a very typical mosfet and can be replaced with many others.
        • KoPhyoe
          • Jul 2021
          • 24
          • Myanmar
          Source and gate (4)
          Gate and drain
          Sorry for my late response ;
          Source and Gate - 4.35 MΩ
          Source and Drain - 00.85 MΩ
          • mon2
            • 14663
            Measure also
            Gate and drain
            • KoPhyoe
              • Jul 2021
              • 24
              • Myanmar
              measure also
              gate and drain
              5.69 megaΩ
              • Sephir0th
                • Oct 2020
                • 1289
                If there is no unexpected Short around PU5 you should proceed with replacing it (PU5).
                FairRepair on YouTube
                • abrahim110
                  [Help Needed] Acer Aspire 5 A517-52G – Removed Onboard RAM, Now Working But Battery Not Charging
                  by abrahim110
                  🧵 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                  I have an Acer Aspire 5 A517-52G-53NB laptop.
                  The onboard (soldered) RAM was faulty, so I physically removed the chip.
                  I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8 GB DDR4 SO-DIMM installed.
                  ✅ System status:
                  • BIOS mod is done (SPD removed)
                  • Laptop boots to Windows normally
                  • RAM is detected and stable
                  ❌ Problem:
                  The battery is not charging:
                  • Power adapter
                  08-06-2025, 06:15 AM
                • Wang Tingting
                  Acer Nitro 5 AN515-57-536Q not charging
                  by Wang Tingting
                  I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
                  report is also good for battery.
                  Following https://www.badcaps.net/forum/troubl...arging-circuit,
                  • DCIN/VCC: 19.1
                  • ACIN/ACDET: 3v
                  • REGN/VDD: 6v
                  • CMSRC : 19v
                  • ACOK: 3.3v
                  • ACDRV: it is 19v, not 25V(when charging, the ACDRV
                  09-10-2025, 01:46 PM
                • CPUFiddler
                  Acer Nitro 5 AN515-45 not charging
                  by CPUFiddler
                  Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
                  This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
                  I've downloaded...
                  03-19-2025, 07:44 AM
                • titomno2
                  Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
                  by titomno2
                  Hi guys,
                  I currently trying to figure out why the laptop of my friend did not charge.
                  It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
                  At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
                  I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
                  My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
                  06-11-2024, 11:52 AM
                • titomno2
                  Acer Nitro AN515-42 Not Charging
                  by titomno2
                  Hi guys,
                  06-11-2024, 02:54 AM
