Asus UX330UA won't power on
  • z0civic
    • Aug 2022
    • 14
    Re: Asus UX330UA won't power on
    Originally posted by mon2
    No. The comment is only to offer closure to the missing part that is for the fuse. In this design, the USB connector is protected on the VBUS pin (supplies power to anything connected) through:
    a) FUSE (missing)
    or
    b) USB load switch (electronic fuse - much faster to react)
    You have the better option on this board.
    This is not the fault of your board not working.
    Oooooh, I understand now. Thank you for explaining I'm learning a lot.
    • z0civic
      • Aug 2022
      • 14
      Does this seem like it's an issue with one of the ICs? If so, that's probably beyond my ability to fix. I would probably just have to replace the board in that case (or if we can't track down what the cause is).
      If it's something like a cap/mosfet/res then I can probably handle it (depending on the size of the component)
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
      • rob777
        Asus TUF won’t run off battery
        by rob777
        I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
        I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
        Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
        Thanks....
        05-27-2025, 07:07 PM
      • Iherduleikgemz
        Asus FX505DY - Battery not charging - BQ24780S
        by Iherduleikgemz
        Hello everyone
        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
        01-13-2025, 03:54 PM
