Acer ES1-571 Winstron no display
  • xf0439
    • Feb 2021
    • 9
    • Spain
    Hello all,
    I have an ES1-571 here with no display, hdmi out or boot.
    Mobo = Wistron Domino_BH
    When pressing the power button the LED, fan and backlight turn on.
    Fan behaves as it would in normal situation.
    All power stages seem good; resistor for internal GPU enable is there.
    Have tried several cleaned bios versions online and later cleaned the original myself but did not make any difference.
    Any suggestions?
    Schematic here: https://www.badcaps.net/forum/attach...5&d=1552137609
  • Sephir0th
    • Oct 2020
    • 1283
    Re: Acer ES1-571 Winstron no display
    A) Detailed visual inspection fur burned components
    B) CapsLock test with external keyboard
    FairRepair on YouTube
    • xf0439
      • Feb 2021
      • 9
      • Spain
      Thanks for your message!
      A: Visual inspection: I have inspected it again and all looks in great state.
      B: CapsLock test: No response at all (there is power on USB ports).
      Any other suggestions?
      • xf0439
        • Feb 2021
        • 9
        • Spain
        The issue seems to be similar to: https://www.badcaps.net/forum/showthread.php?p=886122#7
        and I have asked the author of that topic @DeniS182 if he ever managed to resolve his problem.
        Since most has been ruled out I suspect it's the processor. I have ordered one of those PCIE debug cards as a 'last resort'; in the hope it will still find something
        • Udemzy
          • May 2017
          • 162
          • Guatemala
          Fan and backlight turn on,is it screen back light?
          A picture of it would have help.
          • xf0439
            • Feb 2021
            • 9
            • Spain
            There is not really anything to see; the screen remains black it's just the black with the backlights powered. I mentioned this to indicate (also confirmed it by measuring) that all the power to the display itself is correct.
            The fan turns on for a few seconds and then turns off; once in a while it spins up when needed / as it would do in a normal working situation.
            • xf0439
              • Feb 2021
              • 9
              • Spain
              Anyone any more suggestions what to check?
              • mon2
                • 14415
                Remove the memory stick and check if the logic board offers a POST beep or LED blink code due to the missing RAM.
                • xf0439
                  • Feb 2021
                  • 9
                  • Spain
                  Already tried but there was no indication of any difference; on this MB there is no buzzer nor LED unfortionately.
                  I hope is there will be anything useful trough the LPC interface but the connector is unpopulated and I don't have any suitable connector or ribbon cable to solder to it :/
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    if you have a spare memory that is good try to swap it.
                    • Ariu
                      • Dec 2020
                      • 133
                      i'm having the same issue with this motherboard, all power rails are present,
                      it turns on but no display.
                      PLT_RST# 0V
                      DRAMRST# is pulled low to 0.128V.
                      Does it mean there is a CPU fault?
                      • tommy97
                        • Mar 2023
                        • 160
                        Do you have any mesurements?
                        • Ariu
                          • Dec 2020
                          • 133
                          As I already mentioned, all power Rails are available, the Problem is PLTRST# 0V
                          DRAMRST# 0.128V
                          I muss focus first able on DRAMRST# Signal that is pulled low but I am still confused...
