Macbook 820-00165 No Image , No Backlight
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hello Everyone, Namaste from India,
    We have a Macbook Air A1466 820-00165 that came in for repair for No Backlight. We first replaced the screen to check but the problem was from the motherboard it seemed.
    We treid repalcing the U7701 but didnt help. The image is also lost now. We put back the old U7701 for now.
    Current Findings:
    L7701 - With Screen 0 Voltages with Screen Connected and 8.5V without Screen.
    C7710 - No Voltage.
    P.S There is no chime. The fans are spinning at a high speed and the board is heating.
    Any help would be highly appreciated.
  • mon2
    • Dec 2019
    • 14031
    Re: Macbook 820-00165 No Image , No Backlight
    https://youtu.be/_NR-jnBD7_4
    • Instafixx
      • Jul 2022
      • 374
      • India
      Originally posted by mon2
      Hello Mon2,
      Thank you for the prompt reply, but i amgetting proper value in the resistors showed in this video. R1540 / R1541 /R1542 /R1543.
      • mon2
        • Dec 2019
        • 14031
        Review carefully the lcd connector to be sure there is no short / contact damage.
        Is the tested lcd compatible and known good?
        Do you see the keyboard caps key light toggle? This confirms that the os has booted ok and you are at the login screen. If yes, perform a SMC and PRAM reset.
        Are you booting with a good ssd with a good OS? Remove the SSD and keyboard to check if the fan spin is improved?
        Remove all power and the lcd screen. Meter in resistance mode. Measure the resistance to ground of the inductor L7701.
        What is the resistance?
        Next, attach the display but do not apply any power and repeat the same test.
        What is the resistance with the lcd connected?
        • Instafixx
          • Jul 2022
          • 374
          • India
          Hey ! Thanks for guiding.
          Findings
          1 - No Short or Connectivity Issue in the LCD Connector
          2 - The LCD is compatible and good.
          3 - The Macbook is not booting as i cannot toggle the caps button. Moreover the fan only starts to spin when put on charge.
          4 - Removed Keyboard and SSD but the fan speed is the same.
          5 - Resistance is 5.032 without Power and Display
          6- Resistance is 5.032 with LCD and Without Power
          • mon2
            • Dec 2019
            • 14031
            What is the meter scale used for the resistance scale ?
            Is the reading ~5 k ohms ?
            You are unable to see any graphics even with a flashlight / phone torch mode on the display ?
            • Instafixx
              • Jul 2022
              • 374
              • India
              Hey!
              We have set the meter scale to this. I hope this is right to test the resistance. PFA below !
              We are unable to see any graphics with a flashlight also. We were able to see the apple logo previously before we had replaced the chip.
              • Instafixx
                • Jul 2022
                • 374
                • India
                Update ! Just tried putting the motherboard in a different dead macbook and tried switching on. The fan runs normally but then switches off in 10 seconds and the same thing keeps on happening as if its rebooting or trying to boot.
                • mon2
                  • Dec 2019
                  • 14031
                  Ok. The meter is not in resistance mode.
                  When checking resistance -> start with the WHITE text 200 scale (lowest on your meter) -> check the resistance.
                  If you see '1', this means the meter is trying to tell you the resistance is higher than 200 ohms. So switch to the next higher resistance scale till you have a reading.
                  On your update -> the board is now power cycling ? That is a good sign.
                  Do you see any graphics on the display or is this power cycling without the LCD connected?
                  It is very possible that the backlight IC is not soldered properly. The suggestion for soldering such parts is to flux the part -> good heat BUT low air pressure. Be patient till the balls melt and test this with tweezers across two (2) edges.
                  With a gentle push, the IC should move but do not push to hard. Once the solder is in liquid mode, the IC can be pushed slightly and it will bounce back, naturally. This corrects any solder ball shorts under the IC.
                  Learned this from Louis' videos = 'make the IC dance!'. Again, do not push too hard.
                  This is recommended if you are in doubt of the soldering of this WLCSP package backlight device.
                  • Instafixx
                    • Jul 2022
                    • 374
                    • India
                    Hey! Many thanks for showing me how to check resistance. The resistance with and without LCD is 01.3 to 01.4.
                    There was no graphics at all. Will reball the IC as you said and let you know.
                    • mon2
                      • Dec 2019
                      • 14031
                      See here about the logic board pulsing:
                      https://logi.wiki/index.php/820-00165_Pulsing
                      Pulsing every five seconds
                      Had a case with all voltages pulsing every 5 seconds. In my case it was failed R1275
                      • Instafixx
                        • Jul 2022
                        • 374
                        • India
                        Hey ! There is some weird issue with this board. Its not pulsing now. Its gone back to high speed fan spinning continuosly. i think its now time to say goodbye to it. (
                        • mon2
                          • Dec 2019
                          • 14031
                          Up to you..
                          1) with the high fan spin, does the logic board boot ? Do you see the CAPS LED turn on / off with a press after a while ?
                          2) the high fan spin can be a sensor fault and/or PRAM values need to be reset.
                          3) Using an external dongle, you can test if the video works on an external monitor.
                          • Instafixx
                            • Jul 2022
                            • 374
                            • India
                            1)The board does not boot with high fan speed. No Caps Button LED.
                            2)Have done PRAM reset. Which sensor can be faulty.
                            3) Will check about external monitor and let you know in a bit.
                            • Instafixx
                              • Jul 2022
                              • 374
                              • India
                              Up to you..
                              Hey,
                              Luckily got another Macbook Air (Same Version) fully working condition. When we plugged in the old motherboard in this macbook - We get orange charging light but nothing on the display. No fan movement either.
                              • mon2
                                • Dec 2019
                                • 14031
                                Measure and post the following voltages:
                                3V3_S5
                                3V3_SUS
                                PM_BATLOW_L
                                PM_DSW_PWRGD
                                PCH_DSWVRMEN
                                PM_RSMRST_L
                                PM_PWRBTN_L
                                • Instafixx
                                  • Jul 2022
                                  • 374
                                  • India
                                  Hey! Sorry for the delayed response. Was down with Covid and the cleint was giving no more time hence had to return. Thanks for all the help anyway.
                                  • Constantinos
                                    Macbook Pro A2442 820-02098 No image but has backlight
                                    by Constantinos
                                    Hi all
                                    I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                    He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                    Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                    Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                    From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                    08-24-2024, 09:48 AM
                                  • Roccolade
                                    Macbook Pro 820-01814 no image or backlight
                                    by Roccolade
                                    Hi! I'm a bit new to this whole repair world. But this is what i'm working on:
                                    A Macbook Pro A1990 (820-01814) from 2018. It has no image – or backlight for that matter.
                                    No history of liquid spills or anything. It's fully functional on external monitor - and the webcam works.. But it doesn't seem like the internal display is even detected.
                                    Sometimes the backlight lights up, when booting into recovery mode. (No image still)
                                    That's the only progress I've gotten.
                                    I tested the panel on another Macbook, and the display worked perfectly....
                                    03-07-2023, 05:29 AM
                                  • arevut
                                    Macbook Air 2020 13” model: A2337 backlight is on but no image
                                    by arevut
                                    Hi all! MacBook Air A2337. There are no traces of liquid or obvious damage, the motherboard is visually in perfect condition. The image is displayed on the external screen, but only the backlight works on the internal screen. There is no image, and the camera on the built-in screen does not work. How to exclude during diagnostics that it is the screen that is broken and not the motherboard? What signals should be present on the connector with the screen removed and connected?
                                    02-07-2024, 08:07 AM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                  • imcool
                                    Macbook Air A1466 no backlight no image
                                    by imcool
                                    On this Macbook Air A1466 with 820-00165
                                    I have only 8V on backlight line but no high voltage in boost circuit, I have checked all components like caps and diode and they seems to be ok.
                                    I have noticed that when macbook chimes after turning on there is no image at all even with flash light,
                                    I have tried 2 different OEM LCD and still there is no image,
                                    I see the LCD fades out when i remove power or turn off the macbook.
                                    I have 2 problems
                                    1 No image
                                    2 No backlight, but i have 8VDC on backlight circuit.
                                    12-14-2020, 02:18 PM
