Dell N4010 Does not power on.
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Re: Dell N4010 Does not power on.
    Originally posted by Udemzy
    Unlike other mobo,on this the 3.3v_alw will come before 5v_sus.
    Follow the sequence on page 45
    I didn't check the schematic untill now,your best bet is the power sequence unless it is not given on the schematic.
    I dont have ALW_ON output from IO Chip. Is it a bad IO that needs replacement ? I have flashed both the MAIN and EC bios once though.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Originally posted by IamPritesh
      On Resistance mode ( 200K rage)
      PL9 input side : 130K
      PL 9 output side : 10K ( keeps increasing if you continue to keep the probe attached )
      ALso why does the resistance keeps increasing and is not stable ?
      • Udemzy
        • May 2017
        • 164
        • Guatemala
        Acin in the pic is low with 2.7v,is that what you're getting from the charging ic to the sio chip?
        check rtc section
        32.7khz
        sio vcc,ecrst,acin this is enough to release alw_on ,if not then sio is fualty.
        • IamPritesh
          • Aug 2017
          • 356
          • India
          check rtc section
          32.7khz
          SIO VCC is 3.3
          Which one is ecrst ? is it WRST ( Pin 14 of IO )
          • Udemzy
            • May 2017
            • 164
            • Guatemala
            Yes
