How to use thermo camera for laptop repairing
  • Jane
    • Aug 2010
    • 188
    I have Acer 7745G laptop that does not start. When I connect power supply I can see a big short. I would like to use a thermo camera to detect that short . I use a laboratory power supply and set about 19V but not sure how many amps is still safe to use and at the same time there is enough heat so that camera can see the culprit of the short?
    Can you please advise?
    Thank you
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    Re: How to use thermo camera for laptop repairing
    You need to find shorted rail using a multimeter and then inject maybe 1V and 3-5A there. Then look at it using a camera.
    If you just inject voltage to charging connector, wrong things warm up.
    • piernov
      • Jan 2016
      • 4435
      • France
      https://www.badcaps.net/forum/showpo...02&postcount=2
      2.2. Don't suspect that something is shorted with no reason
      Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
      2.3. Never randomly inject voltage
      Voltage injection is used to find a short to ground. Only consider it after you found that there is a short to ground and after doing a visual inspection trying to find a broken component.
      2.4. Never inject 19V
      If the 19V main power rail is missing, there's a reason, often because a protection kicked in to avoid more damage. For example, the 19V power rail could be shorted to the CPU through a bad high-side MOSFET. In that case, the charging circuit protection kicks in and turns off the DC-in MOSFET. With enough luck, the CPU didn't take too much of a hit yet. If you inject 19V, you are sure to destroy it.
      Always measure exact resistance to ground to see if there is a possibility of high-side MOSFET short. Always start at 1V and check if any of the large BGA (CPU/GPU/PCH) is warming up. Monitor the power consumption.
      • keldeo
        Obscure Pentium laptop, sudden short?
        by keldeo
        I've purchased this weird (and might add appears to have had a fairly rough life) laptop a while ago for $1 at a yard sale. It powered up one time, (saw a POST screen!) Then, never powered again. I've since thrown it in some dark corner, BUT, I've decided to look at it again. First, this seems like a very obscure laptop, mine just has the name "BIT" on it and nothing else. Very similar (same?) can be seen here https://www.vogons.org/viewtopic.php?t=54655.
        At first, I had gotten the weird mini display on the lower part of the laptop to display a few icons, but if I attempted...
        01-02-2025, 03:22 AM
      • playit
        laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
        by playit
        the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
        02-25-2025, 08:15 AM
        Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
        This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
        09-06-2024, 09:30 PM
        Microsoft Surface Laptop Surface Laptop 3 Notebook 3 Specification for Upgrade or Repair
        This specification for the Microsoft Surface Laptop Surface Laptop 3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 boardview and Surface Laptop 3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 01:21 PM
