i have hp 850 g4 problem is prass power button laptop on show only - slow boot to windows i chang bios but problem is still on ssd go to windows not go m2 m2 is ok
hp 850 g4 slow
by futadmytroAsus g713qm-es94 stuck on boot bios problem
sn^M4NRKD02753616E
MB- g533-6050a3250201-MB-A03
Stuck on boot after ROG logo, did not enter to bios
In flash bios , laprop boot but have video issue
orig bios...-
Channel: BIOS Requests ONLY!
06-25-2025, 08:07 AM -
by mpower1226Hi masters, need your help in solving this mystery.
i have a dell optiplex 7090 micro that i bought from local kijiji.
when i turn it on, error comes out saying no hard disk.
i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
it seems as if the computer doesnt recognize the ssd...-
by eltano4i201) Error trying to enter the BIOS
--> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
BOOT PRIORITY ORDER (img-05)
1- Windows Boot Manager
2- SATA HDD
3- NETWORK
4- Debian
2) Error trying to access the BOOT MENU
--> I restarted the notebook and pressed [F10] but the BOOT... -
by jurgenkoppenIt does boot sometimes, but only after hanging for way longer than is normal for a A1398 of this vintage to come to the logo. Half of the times I try to boot it just gives me the question mark folder! I tried the usual SMC and PRAM resets, and I ran First Aid when the machine did decide to boot, but first Aid did not repair anything on the SSD, but came back with SSD is OK. I booted of external drive, and it did boot then.I reseated the SSD, looked at the connection under the scope. Looking clean.I switched to another known good SSD blade, same issue. I tied Safe Mode, but it hangs at login screen,...
by privato89Hello everyone,
I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
Let's begin:
Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the... - Loading...
