IC Marking Codes and Datasheets #2
Hi guys, could someone help me identify this P72EA chip?
It comes from an Acer Aspire Vero
motherboard = HH4A4 LA-M213P
The boardview name is UT9 and i think is a buck converter but im not sure
Attached Filesif you find these attachements useful please consider making a small donation to the site
I already have the boardview but there is no serial number or any additional info on the ic, thanks for sharing nonetheless
Maybe that will help you a bit https://www.badcaps.net/forum/docume...v1-0-boardviewComment
Based on the LA-M211P board schematic, this UT9 is a SY6861B1ABC_SOT23 or G518B1TP1U_TSOT23-6 (Load Switch).Comment
by SMDFleaThread started and edited by piernov and SMDFlea. All members are welcome to contribute to the thread, if you have any
pictures, suggestions, spot any mistakes or want new content adding send me a PM or just make a post. Thanks
EDIT: See "IC Marking Codes and Datasheets #2" for more posts. All members please post comments in thread #2.
__________________________________________________ __________________________________________________ ________
Click on the name next to the post # to view the single post... -
by SMDFleaRicoh Power Management IC`s Marking Codes
The attached pdf titled "Ricoh PMIC`s Marking Codes,pdf" was made by me from the main pdf Ricoh_MARKINGS.
....06-06-2021, 12:29 PM -
by mitsu2kHello folks, I seem to have a lot of trouble when it comes to distinguishing markings on SMD components especially when it comes to the question of whether it is a 1 or an I. for example, I see components marked NI. It looks just like that. However, I cannot tell if that "I" might be a number one instead. Is there a rule of thumb that manufacturers use when using these characters? Attached is an example. This is just one example out of many I come across but it's a good illustration of my point. I appreciate any input....
by dqtechim working on HP Probook 450 g5 with no power issue and found out coil beside this ic is short to ground...i remove the ic and short gone....ic code AQP,...looking on this ic marking code but not found https://www.badcaps.net/forum/troubl...and-datasheets...
by abajorHad someone drop off a laptop in which they were upgrading the ram but forgot to unplug the battery.
Looks like the ram RFI shield shorted a rail going to or coming from a Silergy IC which blasted a component off the board. I'm going to assume it was a cap but really have no way to know for sure since this board schematic doesn't appear to be in the wild yet.
I'm trying to identify the IC model now but it doesn't appear to match any of the Silergy codes from https://www.badcaps.net/forum/troubl...-tablets-and-m... - Loading...
