Yoga Slim 7i Carbon 13 power on, no display
  • tienlk19
    • Jan 2020
    • 16
    • Vietnam
    I have this laptop that powers on, all signal LEDs ok, the battery charges,the keyboard light is on, and the fan spins but nothing shows on screen.
    I measured the coil voltages and resistance, all seems good. The CPU coil is only 3ohm but this is an 11th gen CPU so I think it's ok. All voltages are present though +1.05VALW line fluctuates a bit from 1.02V to 1.06V.
    The CPU gets hot pretty fast after power on (both the CPU and PCH), to the point that without the heatsink, the system turns itself off only after a few seconds.
    I backup the BIOS, Clean ME, replace the bios region from extracted Lenovo website bios and reflash the new bios into the system but the screen is still black.
    I also tried flashing the extracted Lenovo website bios since it's a full bios however the screen is still black.
    One weird thing I notice is that the original bios don't seem to have any DMI info.
    This laptop has dual bios chip,onboard RAM, with no discrete VGA. The Schematic is not available. Model: 13ITL5. Board number: NB2608_MB_V4_PCB. The original bios is attached below.
    Can anyone suggest me what to do next? I'm stuck.
    Last edited by SMDFlea; 07-02-2022, 04:00 AM. Reason: not the bios requests section
    • 21889
    Re: Yoga Slim 7i Carbon 13 power on, no display
    If you have a bios request please post in the bios requests section https://www.badcaps.net/forum/forumdisplay.php?f=40
    By the way,the DMI in your merged bios is at 939000 - 93AFFF .Encrypted.Look for the word LENV
    • tienlk19
      • Jan 2020
      • 16
      • Vietnam
      Thanks for your reply and the information about the DMI region.
      I think the BIOS is fine. After uploading the Clean ME BIOS, I extracted that BIOS again and realized the BIOS is still in "Configured" state instead of "Initialized" using ME Analyzer.
      Then I did some measures while the laptop was powering up. It turns out that the PCH coil voltage while powered on is not 1.05V but 8.7V (the VIN). I guess that explains why the laptop got so hot, the fluctuating S5 1.05V and the "Configured" BIOS .
      At this point, I assume the PCH is already killed!
      I just wonder why the normal 1.05V would jump to 8.7V after powering up.
        • 21889
        Yes it hasn`t fully posted if the bios is still in a configured state. It seems like a shorted high side mosfet killed the pch
        • tienlk19
          • Jan 2020
          • 16
          • Vietnam
          I agree partly. If it was always 8.7V, then most likely the high side Mosfet is shorted. However, what I don't understand is why it is only 8.7V after the laptop Power up. When the laptop is off, the PCH voltage is quite normal, fluctuating around 1.05V.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Is 8.7v on both sides of the coil??
            • tienlk19
              • Jan 2020
              • 16
              • Vietnam
              Yes, it is. 8.7V on both sides of the coil. And I did some measurements on both high and low side Mosfet in resistance and diode mode. Both seem fine.
              Maybe it has something to do with how the driver IC adjusts the output voltage, I myself don't know about this.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Whatever may be the reason, SOC is very likely damaged.
                • to5it0
                  by to5it0
                  10-24-2025, 01:35 AM
                • beogeek
                  Lenovo Yoga Slim 7 14APU8 Bios Request
                  by beogeek
                  I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                  Attached is the bios dump in the state I received it...
                  10-24-2024, 12:54 PM
                • Maxpower3
                  Brand name and Model Type for Lenovo error 2202 product name is invalid
                  by Maxpower3
                  Info for error 2202 LenovoThinkPad models and type
                  Extract from ThinkPad Maintenance Utilities Configuration File
                  plnsrv.ini Version 1.01
                  Some information that may be useful
                  There must also be missing models, add them to the list if you know of any.
                  Code:
                  brand name
                  20B1=ThinkPad Edge E445
                  20B2=ThinkPad Edge E545
                  20BC=ThinkPad Edge E145
                  20BM=ThinkPad X140e
                  20BL=ThinkPad X140e
                  20A3=ThinkPad X230s
                  20AH=ThinkPad X230s
                  20AK=ThinkPad X240s
                  20AJ=ThinkPad X240s
                  02-21-2024, 10:27 AM
                • pavel.kinc
                  Lenovo Yoga Slim 7 Pro 14ACH5 bios
                  by pavel.kinc
                  Hello everyone, I would like to have the bios file for this laptop please. After the bios update it stopped working, only a black screen.
                  Lenovo Yoga Slim 7 Pro 14ACH5 , S/N:PF3DGGVN, motherboard HS45H NM-D691 Rev:1.0
                  There is no working file. Thanks for any help....
                  03-17-2025, 02:16 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
