Macbook Air A1466 820-000165 Fan allways on 6200rpm
  • Mannislav
    • Jun 2022
    • 5
    Hello, i have a Macbook Air A1466 820-000165 where the fan is constantly running 6200rpm, as soon as i hit the power button.
    I already tried a different fan, reset of SMC and PRAM. No difference.
    So i measured the voltage on the connector
    1:5V PP5V_S0
    2:1.6V TACH
    3:4.6V Motor Control
    4:0V GND
    I checked HW Monitor temperatures are in the normal range, no missing signals.
    What can i check next?
  • mon2
    • Dec 2019
    • 14256
    Re: Macbook Air A1466 820-000165 Fan allways on 6200rpm
    Measure the voltages on the following:
    SMBUS_SMC_3_SDA
    SMBUS_SMC_3_SCL
    and post the readings.
    • Mannislav
      • Jun 2022
      • 5
      Thank you for the fast reply. Both signals are 3.3V
      • mon2
        • Dec 2019
        • 14256
        Review this thread:
        https://www.badcaps.net/forum/showthread.php?t=93255
        • piernov
          • Jan 2016
          • 4435
          • France
          Originally posted by Gabr
          after 10 seconds the fan spin starts to rise and reaches maximum speed
          Completely different problems.
          • mon2
            • Dec 2019
            • 14256
            Focus on mosfet @ Q6060. Apply flux and reflow it.
            Confirm the resistance and presence of R6061.
            Confirm the connections in this area to the fan connector.
            • Mannislav
              • Jun 2022
              • 5
              I already found that thread and switched with a known good one.
              Resistance of the Resistors in this area are right.
              Then i reflowed it as best as possible with the connectors nearby, but no difference.
              I also measured from SMC_FAN_0_CTL to R6061 using a testpoint on the backside near C7601 and i get 400/500KOhm depending on which side of the resistor i measure. But reading the schematics there should be no resistance, since it is a trace on the board. Or am i thinking wrong?
              • reformatt
                • Feb 2020
                • 1414
                Confirm prescence of fan tach using a scope to the SMC. If it’s missing, fan will be driven at full speed.
                • mon2
                  • Dec 2019
                  • 14256
                  Try another fan.
                  • Mannislav
                    • Jun 2022
                    • 5
                    I already tried another Fan. I have no scope to Check tach but with mac Fan control it displays RPM Signal.
                    • heruhaerudin873
                      • Jan 2023
                      • Indonesia
                      Fix,change mosfet
