EUROCOM P370EM Scorpius - bad cooling/fan profile - gpu at 95c 7870M
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello. Have this EUROCOM P370EM Scorpius that have bad cooling/fan profile so gpu run on full load at 95c on 7870M
    Vendor wrote that with fn+1 fan goes full throttle but it not work.
    Can be fan profile changed in bios?
  • Ace Perception
    Samsung R530 Bremen motherboard cooling
    by Ace Perception
    I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
    I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
    So I went in pursuit of...
    07-21-2020, 03:05 PM
  • Hondaman
    Liquid cooling?
    by Hondaman
    I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
    (After previous generation hardware [Gigabyte] didn't...
    05-08-2025, 09:37 PM
  • mikey5791
    Help repair Panasonic fridge not cooling
    by mikey5791
    Hi all forum members,
    Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
    After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
    07-16-2025, 02:01 AM
    HERCULES 20V/12V Dual Voltage, PWM Cooling Fan not computer Quality
    I just bought two of these new version of there battery charger because I bought there 12 amp hour battery packs and the standard ones over heat
    https://www.harborfreight.com/20v12v...rger58922.html Charger
    https://www.harborfreight.com/20v-12...ery-59246.html Battery Pack
    https://www.ebay.com/itm/403633842136 Cooling Fan
    I put a battery on the battery charger and you can hear the fan struggling to get up to speed at which it is set to
    Plus when...
    04-09-2023, 01:51 PM
  • Jo3nokokok
    Prochot Ext Asus m409da
    by Jo3nokokok
    Can someone help me.
    I have asus m409da or x409da amd ryzen 3 3200u
    The problem originate from bad cooling, from start its already overheating a lot booting windows causing it to reach 100°C
    And the fan started to fail and i kinda moded the laptop with older laptop fan, its not great but get the jobs done
    And after some time, my relative use the laptop and last time i used it it still great but idk the specific.
    But the person that use this laptop start telling me like the battery was starting to go bad etc2 and now i exchange the...
    07-17-2025, 12:09 AM
