MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
  • Gigabit2
    • Apr 2022
    • 264
    • United Kingdom
    #41
    Re: MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
    So I did cleaning of the area above and now machine fans turn on for one second and then turn off, like quarter fan spin.
    I will replace BIOS chip
    • Gigabit2
      • Apr 2022
      • 264
      • United Kingdom
      #42
      I replaced BIOS chip, issue remains.
      • Gigabit2
        • Apr 2022
        • 264
        • United Kingdom
        #43
        • Gigabit2
          • Apr 2022
          • 264
          • United Kingdom
          #44
          Can anyone help?
          • Gigabit2
            • Apr 2022
            • 264
            • United Kingdom
            #45
            Can anyone advise further?
            • Gigabit2
              • Apr 2022
              • 264
              • United Kingdom
              #46
              Hi @mon2, can you help?
              • mon2
                • Dec 2019
                • 14676
                Hi. See attached.
                Remove all power. Meter in resistance mode.
                Use the lowest scale on your meter.
                Confirm the resistance from the topside of R7020 current sense resistor to the current sense pin CHGR_CSI_P (pin # 28).
                So you are measuring from CHGR_CSI_R_P --> pin #28 of U7000.
                What is the resistance in ohms ?
                Repeat for the other side of the current sense resistor R7020 and CHGR_CSI_N (pin # 27).
                So you are measuring from CHGR_CSI_R_N --> pin #27 of U7000.
                For each, measure right at the pin on the U7000 IC - we want to be 100% sure the traces are reaching the current sense resistor legs.
                • Gigabit2
                  • Apr 2022
                  • 264
                  • United Kingdom
                  #48
                  Hi mon2,
                  CHGR_CSI_R_P --> pin #28 of U7000: 00.5 on 200 mode
                  CHGR_CSI_R_N --> pin #27 of U7000: 00.6 on 200 mode
                  • mon2
                    • Dec 2019
                    • 14676
                    Do you have a lower meter scale on your multimeter ?
                    If not, short the 2 meter leads and post your measurement.
                    Then, again with no power, measure the resistance betwee then the pins of resistor @ R7021. What is the reading ?
                    Then again for R7022.
                    Each must be 10 ohms else something is wrong. These resistor values are critical.
                    • Gigabit2
                      • Apr 2022
                      • 264
                      • United Kingdom
                      #50
                      Hi mon2,
                      No this is lowest scale!
                      00.6 by shorting, on 200 mode.
                      R7021: 10.6
                      R7022: 10.6
                      • mon2
                        • Dec 2019
                        • 14676
                        Ok. The resistor readings are good on their own.
                        Now check again from one side of the resistor to the actual chip pin. No power in resistance checks.
                        If you still read 0.6 then you are on the wrong side of the resistor.
                        Check the OTHER side of the 10.6 ohm resistor(s) to the IC.
                        What are the readings ?
                        • Gigabit2
                          • Apr 2022
                          • 264
                          • United Kingdom
                          #52
                          Hi mon2,
                          Showing 0.6 on one side and 20 on other. See photo, this is where I measured 20:
                          • mon2
                            • Dec 2019
                            • 14676
                            See attached.
                            Measure from the 2 arrow heads as shown for the first check.
                            Reading ?
                            Then repeat for the 2nd resistor check.
                            Reading ?
                            • Gigabit2
                              • Apr 2022
                              • 264
                              • United Kingdom
                              #54
                              1: 07.8
                              2: 08.0
                              • mon2
                                • Dec 2019
                                • 14676
                                Weird - yet you have proper readings up above across each resistor ?
                                R7021: 10.6
                                R7022: 10.6
                                Check again for the resistors only and then trace the side from the resistor pad to the IC pad. This should be 0 ohms for each leg. Otherwise you have a PCB trace that is faulty.
                                Zoom out with your microscope and share another pic with the R7021 & R7022 resistors. You have a PCB trace fault here somewhere.
                                • Gigabit2
                                  • Apr 2022
                                  • 264
                                  • United Kingdom
                                  #56
                                  • Gigabit2
                                    • Apr 2022
                                    • 264
                                    • United Kingdom
                                    #57
                                    Across each resistor now measuring 06.2 on both
                                    • mon2
                                      • Dec 2019
                                      • 14676
                                      Remove one of these resistors and check the resistance out of the circuit.
                                      Each should be very close to 10 ohms.
                                      • Gigabit2
                                        • Apr 2022
                                        • 264
                                        • United Kingdom
                                        #59
                                        Showing 10.3 out of circuit.
                                        • Gigabit2
                                          • Apr 2022
                                          • 264
                                          • United Kingdom
                                          #60
                                          What I do not understand is now out of circuit, I measure other one still in circuit and also showing 10.3! Multimeter misread?
                                          • costivl
                                            Y50-70 turns on, no video, fans dont spin
                                            by costivl
                                            My Lenovo Y50-70 turns on but i have no video, fans dont spin, keyboard lights turns on, no ssd activity.
                                            I removed battery, hdd, rams, bios battery, then pressed power button for 30 sec to drain out all energy, still same thing, i did check both mosfets on power module of the board, pq301 and pq302, i get 20,5V on all pins except one pin that have 8.7V
                                            Connected external keyboard, tried on all 3 usb ports, no leds on the keyboard, neither numlock, checked voltage on usb pins, i only have 5.1V on 1 pin, rest 0V
                                            I have 1.4v on PL502 with...
                                            07-01-2024, 11:38 PM
                                          • costivl
                                            by costivl
                                            Any ideas what to check more?
                                            Thank You
                                            06-13-2024, 11:25 AM
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • huzo
                                            CLEVO N970TF turns fans to the full and goes of
                                            by huzo
                                            The laptop is CLEVO N970TF with i5-9400, RTX2070, i haven't disassembled it yet to know what is the board number, i will update that later, but the issue is laptop turns on normally and works for about 2 minutes,then both fans turn on to the max and in 30 seconds laptop shuts down! Nothing is warm or even close to overheating...
                                            i manage to get linux up and running and monitor the temperatures from all sensors, and the peak one is 51 celsius from a cpu cores...
                                            So something is acting up and thinks the laptop is overheating? How to foul the board into thinking everything...
                                            03-06-2024, 05:28 AM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
