mac 820-00850-A No power on
  • reset1986
    • 308
    • italia
    i have this mac that won't start, no fan rotation, i took measurements and missed the s5 rails
    PP3V3_G3H 3.3V
    PPVIN_G3H_P3V3G3H 12V
    PP20V_USBC_TA_VBUS 20V on two connectors
    PP5V_S5_LDO fluctuates from 0 to 5 there are no shorts
    PM_SLP_S5_L 0V
    PP3V3_S5 0V
    PP1V8_S5,
    PP1V05_S5_PCH_VCCDSW
    PP1V24_S5_PCH_VCCDPHY,
    PPVPCORE_S5
    all missing, what can i check? i noticed the chip
    T2 U3900 heats up slightly but there are no shorts
  • mon2
    • Dec 2019
    • 14182
    Re: mac 820-00850-A No power on
    What is the resistance to ground of this rail ? Something is causing this fluctuation.
    Is the P5V_P3V3G3H_LDO_EN which turns in the above LDO rail ON/OFF fluctuating as well ?
    • reset1986
      • 308
      • italia
      they did not short, resistance PP5V_S5_LDO around 100K
      also P5V_P3V3G3H_LDO_EN is mobile, it varies from 0V to 1.85V resistance 49Kohm
      Thank you
      • mon2
        • Dec 2019
        • 14182
        The enable is linked to the PMU.
        What is the voltage of PMU_PVDDMAIN_EN ? Is it also fluctuating ?
        What is the voltage of P3V3G3H_EN_R ? Is it also fluctuating ?
        * this is a weird one - is this signal actually used ? It leads to parts in the schematic marked as not stuffed.
        • reset1986
          • 308
          • italia
          PMU_PVDDMAIN_EN cell from 0 to 2.6V
          also P3V3G3H_EN_R from 0 to 0.30V
          • reset1986
            • 308
            • italia
            I have noticed that all tensions fluctuate,
            PP3V3_G3H also goes from 2.4 to 3.42
            PPVIN_G3H_P3V3G3H ranges from 12.20 to 12.40V
            only PP20V_USBC_TA_VBUS stable 20V
            tips?
            • mon2
              • Dec 2019
              • 14182
              Not normal. This is an 11A power rail. Does your meter have good batteries ?
              Remove all power. Meter in resistance mode.
              Check the resistance to ground of PP3V3_G3H.
              What is the measurement and the scale used on your meter for this check ?
              U7650 may be defective.
              • reset1986
                • 308
                • italia
                ok PP3V3_G3H high resistance,
                I found l7600 PP5V_G3S resistor 22 ohm, it seems to me low, removed l7600
                P5VG3S_VSW high resistor
                PP5V_G3S U7650 22 ohm
                • mon2
                  • Dec 2019
                  • 14182
                  L7600 PP5V_G3S resistor 22 ohm
                  Yup. That is low on the consumer side.
                  Do you see any damage nearby this regulator ? Any rough looking caps that you would not want to meet in a dark alley ?
                  Do you have a bench power supply ?
                  With the removed coil L7650, you could consider to inject 0v8 (personally always start with a low voltage in case the CPU mosfet is shorted, etc. downstream) and check for heated caps. You can use a thermal camera or IPA.
                  • reset1986
                    • 308
                    • italia
                    removed u7650 the resistance returned to high in l7600, problem on tps51980a
                    I'm looking for a replacement
                    • rizalle
                      • Jan 2022
                      • 7
                      • cibubur
                      good
                      • gleniu
                        Acer Nitro 5 AN517-52-56A5 - won't charge, shorts the AC adapter
                        by gleniu
                        I have a problem with Acer Nitro 5 AN517-52-56A5 (motherboard: GH51M LA-K862P Rev: 1A). I was playing TLoU2, which is a rather demanding game, for a few hours, unless the notebook turned off (my guess is that the battery drained to 0%). Now, when I connect the AC adapter, the LEDs are not coming on and the laptop doesn't charge.
                        It also shorts the AC adapter - I've checked two of them from different manufacturers. Though the AC adapter gives 19,5V as expected, the voltage drops to 0V when I connect it and disconnect from laptop - it comes back to 19,5V when I reset...
                        05-02-2025, 06:48 AM
                      • flusher
                        Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
                        by flusher
                        Bought myself a project thing. Apple MBP16" A2141 820-01700
                        No shorts, no visible waterdamage.
                        Dead. no history.
                        All USBC ports do 20V and charging battery.
                        If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
                        But what PMIC does is that it power cycles(dropping to...
                        02-21-2025, 03:12 PM
                      • Thedan55
                        ps5 2 second power on with fan spin, no shorts
                        by Thedan55
                        Hey everyone I'm totally lost!
                        the consoles power was pulled while gaming by customers wife.
                        I have a ps5 that's got blue light fan spin then powers off. About 2 seconds.
                        I have 12v, 3.3v, 1.8v 5v. From the power supply input prongs, that line of caps, I have 12v on the positive side.
                        I read no shorts anywhere on the board at all. I've injected voltage in 2spots following 2 videos from the cod3r and one other, I saw no current draw at all. i not very experienced with voltage injection so i only did what i saw online that was safe. ive attached pics of...
                        03-14-2023, 01:53 PM
                      • nebulink
                        Nintendo Switch-No Shorts and not charging
                        by nebulink
                        This is a strange one for me. I have a Nintendo switch that turned on initially. The BQ chip was getting very hot. I unplugged and tried a different battery in case there was a problem with them one that came with it. I was told that the battery had been swapped.
                        After trying a new battery, the unit would not turn on.
                        Ammeter shows 15v 0 amp draw.
                        Tested around BG, P13 and M92. No shorts. Decided to swap out BG. Same result.
                        Checked voltages around BG, M92 and Max 177050.
                        Also checked Max 177621.
                        Getting desperate, I changed M92. Nothing
                        I changed...
                        06-23-2024, 03:22 PM
                      • ziko07
                        r9 280 no picture and shorts coils
                        by ziko07
                        Hi, I have this graphic card no image, when power on fans spin but I measured and has only +12v from PCI and power 12v both connectors. also +5v linear present, 3v3 from PCI present. MCU is cold, then I I tried measure again and on coils, 1.5V,1v0, 1.8v, on mcu 0.8v all present and mcu slictly warmed up. After that I tried to put on motherboard and still no image, but now also all those voiltages missing again , only +12v present and 5v
                        Then I measured (see image in red colour) and all those coisl has dead shorts, 0 ohm. I thing when first measuring voltage (I didnt check resistance) was...
                        02-21-2024, 07:11 AM
