i have an issue with my hp 840 g6 laptop.when i remove dmi data from bios file microphone works fine when i insert dmi data microphone hardware not showing and mic not working how can i solve it
Hp 840 G6 Microphone Issue
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by shahnldGood day Experts
I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core... -
by ahmarzoHave a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
Help me to diagnose this issue as there is no shortage in the inputs MOSFET -
by elmarkHP Pavilion 15-CW1002UA
S/N 5CD0251CBC
P/N 7KE54EA
Hello guys!
I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
It powers on OK and has no other issues except the following:- CAPS LOCK does not work at all
- Fn button toggles Flight Mode
- When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
- (with SHIFT pressed: 't%' and 'y^' respectively)
but when I press and hold...06-27-2025, 01:10 AM - Loading...
