ASUS X556UJ_MB rev 2.0 touchpad
  • caprigtx
    • Mar 2022
    • 65
    • Netherlands
    My touchpad is not working , cant find the solution . i tryed 1 other toupad , but same problem. is it directly conected to cpu , or is it driven by other stuff?
  • mon2
    • Dec 2019
    • 13880
    Re: ASUS X556UJ_MB rev 2.0 touchpad
    Hi. See attached. These are boardview screen grabs - no schematics exist from my search in my database.
    1) The trackpad operates using the I2C signals which are 2 line interfaces. One is for data (SDA) and the other for the clock (CLK). Each pair of signals must reach the PCH to communicate.
    2) Do you have a multimeter for testing ? Configure for DC volts scale of 5 volts or higher is ok.
    Check the voltage with red meter lead to pin # 1 = should be ~3v3 and black meter lead to ground - a metal shield on the logic board is ok.
    Start with this confirmation first.
    Next, move the red meter lead to pin # 3 & ground. Voltage reading ?
    Then pin # 4 & ground.
    Then pins 6 and 7 in the same way.
    We want to know the voltage readings for each of these test points when the logic board is powered up. Often such interfaces will get killed from a liquid short or ESD damage and prevent communication to the host (I2C Bus Master controller).
    Post the measurements along with the pins you have tested. Recommend that you do this with the original trackpad unless you are 100% sure the replacement is a valid replacement.
    • xpuko
      • Aug 2016
      • 56
      • Poland
      Try to restore the default bios settings
      • caprigtx
        • Mar 2022
        • 65
        • Netherlands
        I already did that , but no result.
        • steve.rand
          • Jan 2022
          • 13
          Thanks also for this. I just picked up the same laptop and it has three issues; battery not working/charging, trackpad not working and sound chip not detected.
          I have another ASUS touchpad with 7 pins and it also didn't work so suspecting mainboard fault. I'll post back after testing as above.
          • steve.rand
            • Jan 2022
            • 13
            Here are my results. Do we think my trackpad is at fault or mainboard? Thanks!
            1 3.3
            3 1.4
            4 1.4
            6 3.3
            7 3.3
            EDIT: On the trackpad, pin 4 has no voltage!
            • mon2
              • Dec 2019
              • 13880
              Remove the track pad cable and measure the same pins again. Post the voltage readings for each pin.
              • steve.rand
                • Jan 2022
                • 13
                remove the track pad cable and measure the same pins again. Post the voltage readings for each pin.
                1 3.4
                2 0
                3 0
                4 0
                5 0
                6 3.4
                7 3.4
                8 3.4
                Oh and I didn't realise, slight difference; mine is a X555UJ rev2
                • mon2
                  • Dec 2019
                  • 13880
                  Add the track pad and post the voltage readings again.
                  • mon2
                    • Dec 2019
                    • 13880
                    See attached.
                    Remove all power / no battery -> with the trackpad cable attached & meter in resistance mode -> check the resistance to ground for each of the trackpad I2C pins (SCL & DATA).
                    One meter probe on the SCL; other to ground -> what is the reading ?
                    Repeat for the DAT_C line in the same manner.
                    Next, flux and remove D3101 ESD diode array. Measure the voltage again on the above 2 points of interest.
                    Post the readings.
                    • steve.rand
                      • Jan 2022
                      • 13
                      add the track pad and post the voltage readings again.
                      1 3.3
                      2 2.0
                      3 1.4
                      4 1.5
                      5 0
                      6 3.3
                      7 3.3
                      8 3.3
                      • steve.rand
                        • Jan 2022
                        • 13
                        See attached.
                        Post the readings.
                        My pins appear different on x555UJ (attached)
                        1 9.2k
                        2
                        3
                        4
                        5 3ohm
                        6 14k
                        7 14k
                        8 18k
                        • steve.rand
                          • Jan 2022
                          • 13
                          comparing with boardview, I don't have d or q 3101.
                          • mon2
                            • Dec 2019
                            • 13880
                            When you select pin #3 or #4 on the connector, which other parts are mating to these contacts?
                            Perhaps the esd diode is on the other side of the board?
                            • steve.rand
                              • Jan 2022
                              • 13
                              Well i'm more confused now. Those components are missing too and no signs of flux. It was sold to me as having a bad battery and no sound.
                              They then trace to other components also not present, pictures 3/4
                              • steve.rand
                                • Jan 2022
                                • 13
                                This is nearly the exact board version I have:
                                https://devicedb.xyz/dev/file/3886-a...boardview-asc/
                                I think the boardview files here at badcaps for X555UJ are not quite for this one.
                                Mine is 60nb0ag0-mb1112
                                I traced continuity from pin5 to this chip:
                                • mon2
                                  • Dec 2019
                                  • 13880
                                  As a test, flux and remove this part. Test again without this part.
                                  • steve.rand
                                    • Jan 2022
                                    • 13
                                    Will do! So far though, would you say there is anything obvious to suggest a mainboard fault? There isn't much on the touchpad and I have continuity to it via the ribbon cable but it's relatively cheap to replace. (albeit a 2 month shipping time)
                                      • 20438
                                      Originally posted by steve.rand
                                      1 3.3
                                      2 2.0
                                      3 1.4
                                      4 1.5
                                      5 0
                                      6 3.3
                                      7 3.3
                                      8 3.3
                                      Pin 5 is actually pin 4 GND
                                      60NB0AG0-MB1111 boardview https://www.badcaps.net/forum/showpo...76&postcount=4
                                      • steve.rand
                                        • Jan 2022
                                        • 13
                                        Yeah I think that's the same as my link above. I will triple check that pin.
                                        • jamesp
                                          Asus TP412FA keyboard and touchpad not functioning
                                          by jamesp
                                          Hello guys,
                                          need help, i have a laptop that i encountered having keyboard and touchpad not working, not immediately going to BIOS i already tried replacing even just the keyboard with a new one but still problem exists. now i only realized to checked it from bios to erase doubts. i found out both touchpad and keyboard are working only on BIOS but not on windows.
                                          since i cant just reformat the said laptop, i tried installing MyAsus utility and updated my drivers , and windows update as well. i included updating the bios to latest 3.08 version. still kb and touchpad is working on bios...
                                          08-18-2024, 11:02 AM
                                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-07-2024, 02:50 AM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • Rhaverz
                                          My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
                                          by Rhaverz
                                          Good afternoon friends
                                          I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
                                          I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
                                          I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
                                          03-30-2023, 03:56 PM
