2x Lenovo Ideapad 320 power problem - whole series problem
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3607
    • slovakia
    Hello.I have two Lenovo Ideapads 320 with the same problem.
    NO voltage after first mosfet. after replace first mosfet have pulsing voltage around 3.5V after first mosfet, but still no charge or power. i replace charger ic BQ24780S but nothing changed. but when i connect GOOD battery everything works. when battery not connected or connected BAD/low voltage/ batery i have no power.
    When i short first mosfet just for a while everything works even without battery until charger remove
    i measured that almost everything works but have no ACDRV/pulsing to 3.5V after mosfet replace/, no ACOK without battery
    pu301
    pin28 vcc 19v ok
    pin6 ACDET 2.8v ok
    pin5 ACOK 0v ok
    pin3 CMSRC 0v/pulsing to 3.5V after mosfet replace/
    pin4 ACDRV 0v/pulsing to 3.5V after mosfet replace/
    pin24 REGN 6v ok
    i see MANY of these model with same error. have somebody some ideas?
  • mon2
    • 14315
    Re: 2x Lenovo Ideapad 320 power problem - whole series problem
    Hi.
    1) can you link or post the schematic for the logic board? Have not yet checked my schematic database for the same.
    2) pin #5 ACOK PIN = 0v is not OK.
    3) remove all power. Meter in resistance mode. Check the resistance to ground of ACOK PIN #5.
    What is the resistance and scale used on your multimeter?
    • mon2
      • 14315
      Ok - believe to have found the schematic.
      1) Logic board block diagram references the charger IC as PU301 but the actual schematic shows as PU201. Nice.
      2) Review to check which resistors are present on the ACOK signal line.
      Post the location and do check the voltage on the other side of the resistor - do you have ~6v on the other side of PR214 ?
      Confirm which of these 3 resistors are on your logic board.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3607
        • slovakia
        only one as on schematics
        • mon2
          • 14315
          1) Remove all power. Meter in resistance mode.
          Check the resistance of the mosfet pins @ PQ202, PQ203 (battery mosfet), PQ205 and PQ206 to confirm that they are not defective.
          Multimeter in resistance mode (start with the lowest scale).
          Check the resistance across the mosfet pins as follows:
          source (1-2-3) & drain (5-6-7-8)
          source (1-2-3) & gate (4)
          gate (4) & drain (5-6-7-8)
          Post the readings for the each mosfet. Also post the scale on your meter used for the measurements.
          If you see a '1' on the meter, this means the resistance is higher than the meter scale so switch to the next higher scale.
          2) Confirm the presence and resistance of parts @ PR206 and PR207.
          3) Confirm the soldering of the replacement charger IC is ok.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            If evrything fails try jumpering a wire from drian of PQ311 to PR311,pin2 and see if it works. Take note that Jumper should be soldered on PR311,pin2 only. This will bypass the current sensing but on most boards this works with BQ24780S.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3607
              • slovakia
              nope still the same. work only with good battery
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3607
                • slovakia
                WTF?
                i see on charging ic ADP signals, but charger dont have checking for Wattage by middle pin. I have one Asus i think k54 that have same problem, but on original charger everything works. so i unplug charger cable from my PSU and attach it to lenovo charger. Connect to laptop and BAM. everything works normal. even without battery.
                So how PSU make charger ic to not start, but without checking of middle pin?
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  Is tha adapter with small pin connector? It has a detection to see if theis full inserted and it will not start otherwise do you have a picture of the connector.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3607
                    • slovakia
                    its this cable
                    https://www.aliexpress.com/item/1005...69e31802xYxdc3
                    and this PSU DPS3005
                    https://www.aliexpress.com/item/1005...61951546%21sea
                    maybe this PSU works some other way than charging IC liked
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Yea maybe i see not a charger detiction pin on this connector. Is the pin same lenght as they from original charger. I got a case where i had one if i shorted two pins on the connector board works. I do not know anymore it was acer or lenovo laptop that was the problem. Replacement adapter i got from client was a little shorter then the orinal and doesn't close adapter detection pin.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3607
                        • slovakia
                        i use this cable to attach to charger with cut cable. so only thing that changes is charger, not cable
                        • ipn00tic
                          Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
                          by ipn00tic
                          Hello everybody,
                          I'm learning alone at home (with you) of course.
                          I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
                          The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
                          I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
                          The VCC_GT power...
                          03-01-2024, 05:32 AM
                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          09-07-2024, 05:20 AM
                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-07-2024, 05:00 AM
