Ask HP ProBook 450-G2 No Backlight LA-B181P
  • sikocan
    • Oct 2019
    • 344
    BOARD: LA-B181P
    LAPTOP: HP probook 450 g2
    ISSUE: NO BACK LIGHT.
    HISTORY: Unknown
    CONDITION: Works normal without backlight, has picture. Works external screen.
    Repair Steps: 3 different LCDs tried so far. No damage/burnt or liquid spills.
    Attached is the LVDS connector readings with LCD, without LCD and their Voltages.
    Also attached is the PDF schematics.
  • mon2
    • Dec 2019
    • 14672
    Re: Ask HP ProBook 450-G2 No Backlight LA-B181P
    Another case the same on this forum.
    Measure and post the voltage readings of each pin of UT6 AND gate.
    • sikocan
      • Oct 2019
      • 344
      The readings are:
      1. 0
      2. 3.39
      3. Ground 0
      4. 3.39
      5. 3.39
      I could be wrong on numbering, there is no IC in this location, just pads. I've attached the image.
      • sikocan
        • Oct 2019
        • 344
        I have tried a new BIOS file same result. The cable in continuity looks good to all pins with a cable.
        • mon2
          • Dec 2019
          • 14672
          Ok. Appears to be not stuffed so is bypassed.
          Confirm the voltages to ground on pins 8 & 9 on the LVDS connector.
          • sikocan
            • Oct 2019
            • 344
            Pin 8 3.11
            Pin 9 3.39
            • sikocan
              • Oct 2019
              • 344
              On ERS Discord, a friend mentioned INVTPWM is for brightness. Before BIOS reset it was 3.39V and after reset it was 3.11. Hence the difference in my original readings and current readings. Is this correct?
              • piernov
                • Jan 2016
                • 4439
                • France
                Cable is suspect if it's not been replaced. Voltages should be checked on LCD side to confirm.
                • sikocan
                  • Oct 2019
                  • 344
                  Just an update to LCD issues on HP ProBook - No solution yet. I have attached PDF file which shows LCD side Pin voltages when it's turned on. Let me know what you think. Green background of a cell means there is a match on LCD. Red means V on screen but no corresponding match on LVDS.
                  • sikocan
                    • Oct 2019
                    • 344
                    Pin No 9 is fault. resoldered fixed.
                    • trepachka
                      HP Probook 450 G8 Boardview+Schematics - screen backlight issue
                      by trepachka
                      I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
                      Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
                      Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
                      03-16-2024, 12:32 AM
                      HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-07-2024, 07:12 AM
                      09-07-2024, 06:40 AM
                      HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                      This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                      09-07-2024, 05:50 AM
