Problem transfer file from a samsung sgh-e710
  • falcontech
    • Oct 2013
    • 484
    • italy
    Good morning everyone
    I need your help because I have to recover photos from an old samsung sgh-e710, the cell phone has only infrared to communicate with the computer and the usb cable (purchased for this reason). I have downloaded both PcStudio 3 and Easy studio but I cannot show him the phone, I probably need the drivers that I cannot find online, currently I have tried with windows 10, but if it is necessary I can install windows xp on a computer, I await the your help thanks
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Problem transfer file from a samsung sgh-e710
    https://drivers.softpedia.com/get/Ot...er-20011.shtml
    • mon2
      • 14731
      The phone should have a removable memory card somewhere on the logic board. Suggest to use a memory card reader and data recovery s/w (if required) to access the photos.
      Test (without writing onto the same memory card) a mix of data recovery programs as they do vary in success of restoring lost photos.
      • falcontech
        • Oct 2013
        • 484
        • italy
        the download takes me to a page where it asks for a login and there is no possibility to register I had already seen this download and all the others lead to this HAMA page
        • falcontech
          • Oct 2013
          • 484
          • italy
          where would this memory card be found? do i have to take the phone apart?
          • SluggerB
            Help with trying to fix phone that is not charging (Pics inside)
            by SluggerB
            I have two TCL A30 phones.
            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
            New Phone: Works fine, bought as a donor board to try and repair Old Phone
            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
            08-12-2024, 08:11 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
            09-07-2024, 05:50 AM
          • reformatt
            Intel iMacs, 3rd party SSD failures and Fusion setups
            by reformatt
            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
            12-18-2024, 10:34 PM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
