Laptop LED Repair
  • max_sneka2
    • Mar 2022
    • 84
    • iraq
    Laptop LED Repair
    Hi every one ...
    Is there any way to repair laptop screen that have blinking and the reason is from the board inside it and not from lcd or drivers or discrete vga ??
  • mon2
    • 14662
    Re: Laptop LED Repair
    The backlight is blinking / flashing ? The LCD is a known good panel ?
    You can check if the backlight voltage is pulsing or not at the LCD connector.
    Which logic board ? Do you have a schematic ?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • ahmarzo
      Hp 15-cs laptop 5 times dc jack blinking white
      by ahmarzo
      I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
      First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
      Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
      But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
      12-28-2024, 04:46 AM
    • ronaldo17
      Power button blinking, Laptop Hp pavilion gaming 15-ak DAX1PDMB8E0 rev E
      by ronaldo17
      When I press the power button, nothing happens. All I can see is the power button blinking and never stopping.
      Here’s everything I’ve tried:
      -Removed the battery
      -Changed the power adapter
      -Replaced the CMOS battery
      -Changed the RAM.
      But my laptop is still blinking. However, in the morning after I wake up, the laptop will turn on.
      Here is my spec:
      -i5 6300hq
      -Gtx 950m
      -Hp pavilion gaming 15-ak030tx Laptop DAX1PDMB8E0 Rev E
      Now, I'm trying to fix the motherboard using the schematic I found
      If anyone can help...
      08-25-2025, 09:02 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
