please help toshiba c850 no display just work on external
  • doctormasry
    • Dec 2019
    • 108
    • giza
    toshiba c850
    plf/plr/csf/csr DCS mb rev :2.1
    no display but it work in crt conn
    when i connected to lcd monitor (crt external ) work good and data and boot win
    but there is no data on it's monitor (internal)
    i changed screen but no new
    i changed i/o but no new
    reprogram bios but no new
    two pictures attachments for LVDS connector voltage measurement
    thanks
  • BalkanBoy
    • Feb 2017
    • 69
    • Croatia
    Re: please help toshiba c850 no display just work on external
    Have you checked hall sensor? Maybe it thinks lid is closed?
    • doctormasry
      • Dec 2019
      • 108
      • giza
      i checked it and change it too no new
      • mon2
        • Dec 2019
        • 14677
        Watch this:
        https://youtu.be/5Tv2HnU6Ouo
        • doctormasry
          • Dec 2019
          • 108
          • giza
          Originally posted by mon2
          thanks
          do you mean vga chip is problem
          and the problem solved by dis to uma conversion ?
          • mon2
            • Dec 2019
            • 14677
            The dude in the video is using hot air to temp fix the the video controller. If your unit has one then he is claiming that 99% of the time it is the fault.
            Perhaps consider to test in the same way with the heat gun to see if your LCD comes to life or not.
            BTW: Do unplug the adapter (which he did not do) in this video while he was working with the logic board.
            • doctormasry
              • Dec 2019
              • 108
              • giza
              thanks for you @mon2
              i converted it from dis to uma and work well
              thanks again pro
