Toshiba L850-B387 (external display ok internal not coming)
  • SR IT SOLUTION
    • Jan 2023
    • 61
    • INDIA
    i have Toshiba L850-b387
    part no : PLF/PLR/CSF/CSR DSC MB REV:2.1
    the problem is external display on monitor is ok, but
    no display comes in laptop screen
    any one help??
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    No measurements posted and you expect help?
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      First measure te on display connector if you got ,main power rail and 3,3✓
      • SR IT SOLUTION
        • Jan 2023
        • 61
        • INDIA
        LVDS connector measurements
        pin 2--19v coming
        pin 36 --lcd_bl_pwm_c not present
        pin 38 and 40-- +Lcd VCC not present
        PIN 39-- +3VS PESENT
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          And whitout screen connected always disconnect battery when you Mess with connectors.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            U4501-voltage on all pins?
            • SR IT SOLUTION
              • Jan 2023
              • 61
              • INDIA
              u4501--- only 5 number pin 3.3v
              rest of pins--0 v
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Check R4512/13 for value. Post the voltage on both sides of these resistor. What is the resistance to GND on pin1 of U4501?
                • baglaivlad
                  A1534 2015 820-00045 internal display not detected, but external works
                  by baglaivlad
                  Hi everyone!
                  Trying to repair A1534 2015 macbook. The keyboard and touchpad was liquid damaged by coke, but the MLB has no signs of corrosion. The laptop successfully turned on, but missed a display flex. Replaced keyboard, touchpad and display flex, but still no image on the internal display (no backlight as well). When connecting to the external display the laptop works just fine (I have an image).
                  It seems like internal display is not recognized. I tried multiple known-good displays and display flexes, the outcome is the same: no life on the display.
                  It lead me to believe...
                  06-08-2024, 02:30 PM
                • eurowill
                  a2141 820-01700 internal display not working / external works
                  by eurowill
                  Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
                  Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
                  07-23-2024, 10:06 AM
                • fasda1984
                  GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died
                  by fasda1984
                  , Hello have same GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died without crash or something, just started in black screen, checked driver in devices and have only external display, no more internal... Any suggestion? External working fine, no problems no errors
                  06-22-2024, 01:43 AM
                • DqMagetz
                  Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                  by DqMagetz
                  Good day!
                  I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                  Here are the voltage readings:
                  • Input – 19V (stable)
                  • +LCDVDD – 3.3V briefly, then drops to 0V
                  • EDP_HPD – 3.3V briefly, then drops to 0V
                  • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                  • EC BKOFF# – 1.8V briefly, then drops to 0V
                  • PANEL_OD_EN – 0.3V
                  Is it possible that the EC chip is corrupted or damag...
                  07-12-2025, 09:37 PM
                  09-06-2024, 05:27 AM
