MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powered
  • duwane
    • Mar 2022
    • 57
    • New Zealand
    Hi All.
    I have a very strange issue that I have been trying to fix for a few days now.
    Model: MacBook Pro A1278
    Logic board: 820-3115-B
    Laptop history:
    No visible liquid damage/corrosion, but found evidence of other rework (flux) so any signs of liquid may have been cleaned. The laptop went in for a battery replacement but wasn't working afterwards and was deemed unfixable (as told to me by previous owner). Not sure if this was by Apple, or another repair company. The flux found was found around ISL6259HRTZ, so can assume it was replaced at some stage. Also there is one missing pin in one of the memory slots. Looks like it snapped at some stage. The remains of this broken off pin removed by me, so not shorting anywhere.
    The issue:
    - No boot at all while on charger or battery
    - No charger light at all
    - 10mA constant current draw from power supply
    - ADAPTER_SENSE line is 0v, but not shorted to ground
    - SMC_BC_ACOK(CHGR_ACOK) is short to ground, but only when the board is powered (by either adapter or battery)
    - PPBUS_G3H fluctuates between 0v and 3v when connected to charger, but voltage drops steadily while measuring towards 0v
    - PPBUS_G3H shows 12.33v when connected to a charged functional battery (but SMC_BC_ACOK still shows as short to ground, and still no boot or fan spin)
    - Most of the S5 rails not present - due to missing PPBUS_G3H I guess
    - PP3V42_G3H is present and measures 3.45v
    What I have tried:
    I have tried a known working DC in board with the exact same results.
    I have replaced the following components with no noticeable changes:
    - U7000 (ISL6258) - Replaced 3 or 4 times, so no chance all of these were faulty
    - Q7510, Q7520
    - U6900
    - Checked for shorted caps and bad resistors on the SMC_BC_ACOK line asper touch points indicated by Boardview
    I Have removed the following components in an attempt to get rid of the SMC_BC_ACOK short with no results. (I can't replace these as I am waiting for replacement parts to arrive)
    - Q7030, Q7035
    - U4900 (SMC)
    - Q6901
    Until I can figure out why there is no voltage showing on ADAPTER_SENSE I am pretty sure I will not be able to get PPBUS_G3H back either. Really baffling me at the moment, and hoping there is something obvious that I am missing? Could there be some sort of short inside the board that only shows up when powered?
    Any and all help appreciated!
    Thanks.
  • mon2
    • Dec 2019
    • 14691
    Re: MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powere
    What is the voltage of CHGR_ACIN ? (U7000, pin # 3)
    Never mind this measurement - U7000 is working since you have PPBUS_G3H.
    Confirm that the soldering is ok for U7000, pin # 14 (CHGR_ACOK).
    Confirm that R5087 is present and its value. This CHGR_ACOK is an open-drain output and respectively requires a local pull-up resistor = R5087 in this case to be present. Then R5087 must have a pull-up voltage (ie. PP3V3_S5_SMC) to be function to allow for the '1' state.
    After the above, the MAXIM single wire communication IC will be powered to light up the external adapter light.
    • reformatt
      • Feb 2020
      • 1528
      CHGR_ACOK is open drain on ISL chip. Should be pulled high to PP3V3_S5_SMC by a pullup. This comes from the ISL......PPBUS_G3H is 12.3V, this indicates to me that the SMC isn't communicating to the ISL. Most common cause of that is SMC is stuck in reset or issue around the power rails to the SMC.
      • mon2
        • Dec 2019
        • 14691
        Ditto brother...
        • duwane
          • Mar 2022
          • 57
          • New Zealand
          Thanks for the help @mon2 and @reformatt
          Have rechecked pin 14 of U7000, and can confirm no short when board not powered.
          R5087 is a strange one. Unpowered the value of this resistor shows as the correct value (470k Ohm), but when powered shows as short to ground on pin 1 (as this is SMC_BC_ACOK). The voltage when measured across R5087 pins when board is powered is showing as 3.45v and Ohm value shows as OL.
          P3V3_S5 is showing as 0v at this stage.
          P3V3_S5_AVREF_SMC showing as 3.28v
          P3V3_S5_SMC_VDDA showing as 3.45v
          @reformatt PPBUS_G3H is only 12v when a battery is connected. When no battery is connected, PPBUS_G3H only reads as milli volts.
          • mon2
            • Dec 2019
            • 14691
            Do note that resistance checks can only be performed with all power OFF / REMOVED from the logic board.
            if you see PPBUS_G3H on with battery only then the battery mosfet @ Q7055 is engaging.
            Remove the battery. Using only the external power adapter, post the voltages of the attached points of interest.
            Also measure the voltages on both sides of fuse @ F6905.
            • duwane
              • Mar 2022
              • 57
              • New Zealand
              Thanks again @mon2
              Thanks, yes I realised that after posting. Been a long night/day lol
              Noted. All the S5 voltages I posted in my previous post are with only desktop power supply connected (no battery connected). Only voltage that seems to change between having battery connected and not connected so far is PPBUS_G3H it seems.
              16.46v measured both sides of this fuse to ground.
              • mon2
                • Dec 2019
                • 14691
                Wait.. you are not using an official magsafe power supply ?
                You cannot do that - there is a single wire communication IC from Maxim (formerly Dallas Semiconductor) @ U6900 that will ping the external power supply.
                Only the magsafe head (which features a proper single wire communication IC inside as well) will respond to the query.
                • duwane
                  • Mar 2022
                  • 57
                  • New Zealand
                  I am using a BY-3200 power cable designed for testing Macs that I got from Union Repair.
                  I have a second A1278 with the same board in it, and thats what I am basing my findings on. It boots using the same power supply and cable, and even with the same DC In board
                  • mon2
                    • Dec 2019
                    • 14691
                    OK. PPBUS_G3H is still a suspect when powered by your external power supply only.
                    1) Confirm that you have PP3V42_G3H_REG with ONLY the external power adapter (your BY cable should be fine).
                    2) See post #2 of this thread and review the voltage @ CHGR_ACIN.
                    Based on the non-existent PPBUS_G3H with the adapter only case, U7000 is not operating properly - for some reason.
                    Also, be sure that U7000 is being powered via
                    PP5V1_CHGR_VDDP
                    PP5V1_CHGR_VDD
                    PPCHGR_DCIN
                    3) The power on order chart on sheet # 3 of the schematics will be logical to follow.
                    • duwane
                      • Mar 2022
                      • 57
                      • New Zealand
                      Agreed. It is doing my head in lol. I have already replaced it 3 times with new chips, so highly unlikely to be a bad chip, but could be possible I guess.
                      PP3V42_G3H_REG = PP3V42_G3H = 3.45v as measured @ pin 1 of C6999
                      CHGR_ACIN (@pin 3 of U7000)= 3.86v - About the same on working board.
                      PPCHGR_DCIN (Pin 2 of U7000) = 2.36v - This measures 15,9v on the working board, so this could be the main issue. Will investigate this further in bit.
                      PP5V1_CHGR_VDDP
                      PP5V1_CHGR_VDD
                      PPCHGR_DCIN
                      PP5V1_CHGR_VDDP & PP5V1_CHGR_VDD both measure 2.86v. The test board measures 5v for these two, so we have an issue here too grrr.
                      PPCHGR_DCIN: Currenty measures 2.86v. As mentioned above, will investigate further and advise in a bit if I find anything.
                      Will work through this and see what I can find, but the 2 lines above that don't match the working board seem like likely candidates?
                      • mon2
                        • Dec 2019
                        • 14691
                        This is major. Review this area carefully. Start with removing all power. Meter in resistance mode.
                        Check the resistance from the measured pin to a point where you know the power rail is ok. Again no power. This could be trace break or similar.
                        Compare each measurement to the known good board.
                        Time for beauty sleep here...my basketball team lost (western semi-final). will check the forum in the morning. Your last post has some good areas to investigate.
                        For now, do not replace u7000. It may be ok.
                        • reformatt
                          • Feb 2020
                          • 1528
                          Check D7005.
                          Don't replace components en masse unless you have a valid reason. This is a good way to introduce additional faults and then it makes it difficult to help.
                          All troubleshooting should be done with adaptor only; if you are chasing anything to do with Magsafe, you should always use an original adaptor, trust me.
                          • duwane
                            • Mar 2022
                            • 57
                            • New Zealand
                            Fair enough. Thanks for the help so far. Hopefully I will have found the issue by the time you wake up lol
                            • duwane
                              • Mar 2022
                              • 57
                              • New Zealand
                              Originally posted by reformatt
                              Check D7005.
                              Thanks @reformatt. I understand, however I don't actually have a magsafe charger for this model sadly, so have no choice at this stage. Also I have no way to tell what current the board is drawing if I use the actual charger.
                              As far as replacing componenets, I only changed what seemed to not be giving correct outputs, but as you say, this could have introduced other issues, so will slow down on the replacements for future fixes.
                              Edit. Forgot to mention. D7005 is good Measured with diode test mode. When powered it has 16.45v on both inputs, and the same on the output
                              • reformatt
                                • Feb 2020
                                • 1528
                                So if the output of D7005 is ok, that means from your earlier statements you have a 14V drop across R7005? Check R7005 resistance and resistance to ground from pin 2 of the ISL.
                                • duwane
                                  • Mar 2022
                                  • 57
                                  • New Zealand
                                  I rechecked D7005, and yes 16.5v on each ping 1 and 2, and 16.3v on pin 3. Pin 2 of U7000 measures 2.4M ohms to ground (without a DCIN board attached), but the resistance drops constantly until it stabilises at around 1.6M ohm after about 30 seconds after unplugging the power. I removed one pin of C7005 to take it out of circuit, and R7005 gives and immediate value of 300ohm without any fluctuation in value.
                                  R7005 measured inline without a DCIN board attached reads 50k ohm to start with also drops for 20 seconds or so until it stabilises at around 1k ohm. According to the schematic I have, it should be 20 ohm, so must be something else inline that is throwing off the reading.
                                  • reformatt
                                    • Feb 2020
                                    • 1528
                                    Not sure what your logic is re DC IN board since there is a diode in between, but R7005 is clearly faulty.
                                    • duwane
                                      • Mar 2022
                                      • 57
                                      • New Zealand
                                      Yeah I am trying to find a replacement. The working board's R7005 measures 1kohm, so what should I replace it with? 20 ohm as per schematic, or as per other board 1k ohm?
                                      Regarding the logic with removing the DC IN board, only mentioned it as it has caused different readings with some values for me in the past, so now I remove it before taking any measurements.
                                      Regarding SMC_BC_ACOK, it is still short to ground when the board is powered, which is not correct either I am guessing. Measured using diode tester to ground (positive terminal on ground) it measures a 0.5v drop, but the minute I connect power to the board it direct shorts to ground.
                                      • duwane
                                        • Mar 2022
                                        • 57
                                        • New Zealand
                                        Sorry, correction: R7005 on the working board measures 130ohm, not 1k. Measured the wrong one.
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
