MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powered
  • duwane
    replied
    Re: MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powere
    Originally posted by mon2
    Wait.. you are not using an official magsafe power supply ?
    You cannot do that - there is a single wire communication IC from Maxim (formerly Dallas Semiconductor) @ U6900 that will ping the external power supply.
    Only the magsafe head (which features a proper single wire communication IC inside as well) will respond to the query.
    I am using a BY-3200 power cable designed for testing Macs that I got from Union Repair.
    I have a second A1278 with the same board in it, and thats what I am basing my findings on. It boots using the same power supply and cable, and even with the same DC In board
  • mon2
    replied
  • duwane
    replied
    Thanks again @mon2
    Do note that resistance checks can only be performed with all power OFF / REMOVED from the logic board.
    Thanks, yes I realised that after posting. Been a long night/day lol
    if you see PPBUS_G3H on with battery only then the battery mosfet @ Q7055 is engaging.
    Remove the battery. Using only the external power adapter, post the voltages of the attached points of interest.
    Noted. All the S5 voltages I posted in my previous post are with only desktop power supply connected (no battery connected). Only voltage that seems to change between having battery connected and not connected so far is PPBUS_G3H it seems.
    Also measure the voltages on both sides of fuse @ F6905.
    16.46v measured both sides of this fuse to ground.
  • mon2
    replied
  • duwane
    replied
    What is the voltage of CHGR_ACIN ? (U7000, pin # 3)
    Never mind this measurement - U7000 is working since you have PPBUS_G3H.
    Confirm that the soldering is ok for U7000, pin # 14 (CHGR_ACOK).
    Confirm that R5087 is present and its value. This CHGR_ACOK is an open-drain output and respectively requires a local pull-up resistor = R5087 in this case to be present. Then R5087 must have a pull-up voltage (ie. PP3V3_S5_SMC) to be function to allow for the '1' state.
    After the above, the MAXIM single wire communication IC will be powered to light up the external adapter light.
    Thanks for the help @mon2 and @reformatt
    Have rechecked pin 14 of U7000, and can confirm no short when board not powered.
    R5087 is a strange one. Unpowered the value of this resistor shows as the correct value (470k Ohm), but when powered shows as short to ground on pin 1 (as this is SMC_BC_ACOK). The voltage when measured across R5087 pins when board is powered is showing as 3.45v and Ohm value shows as OL.
    P3V3_S5 is showing as 0v at this stage.
    P3V3_S5_AVREF_SMC showing as 3.28v
    P3V3_S5_SMC_VDDA showing as 3.45v
    @reformatt PPBUS_G3H is only 12v when a battery is connected. When no battery is connected, PPBUS_G3H only reads as milli volts.
  • mon2
    replied
    Ditto brother...
  • reformatt
    replied
    CHGR_ACOK is open drain on ISL chip. Should be pulled high to PP3V3_S5_SMC by a pullup. This comes from the ISL......PPBUS_G3H is 12.3V, this indicates to me that the SMC isn't communicating to the ISL. Most common cause of that is SMC is stuck in reset or issue around the power rails to the SMC.
  • mon2
    replied
    SMC_BC_ACOK(CHGR_ACOK) is short to ground
  • MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powered
    Hi All.
    I have a very strange issue that I have been trying to fix for a few days now.
    Model: MacBook Pro A1278
    Logic board: 820-3115-B
    Laptop history:
    No visible liquid damage/corrosion, but found evidence of other rework (flux) so any signs of liquid may have been cleaned. The laptop went in for a battery replacement but wasn't working afterwards and was deemed unfixable (as told to me by previous owner). Not sure if this was by Apple, or another repair company. The flux found was found around ISL6259HRTZ, so can assume it was replaced at some stage. Also there is one missing pin in one of the memory slots. Looks like it snapped at some stage. The remains of this broken off pin removed by me, so not shorting anywhere.
    The issue:
    - No boot at all while on charger or battery
    - No charger light at all
    - 10mA constant current draw from power supply
    - ADAPTER_SENSE line is 0v, but not shorted to ground
    - SMC_BC_ACOK(CHGR_ACOK) is short to ground, but only when the board is powered (by either adapter or battery)
    - PPBUS_G3H fluctuates between 0v and 3v when connected to charger, but voltage drops steadily while measuring towards 0v
    - PPBUS_G3H shows 12.33v when connected to a charged functional battery (but SMC_BC_ACOK still shows as short to ground, and still no boot or fan spin)
    - Most of the S5 rails not present - due to missing PPBUS_G3H I guess
    - PP3V42_G3H is present and measures 3.45v
    What I have tried:
    I have tried a known working DC in board with the exact same results.
    I have replaced the following components with no noticeable changes:
    - U7000 (ISL6258) - Replaced 3 or 4 times, so no chance all of these were faulty
    - Q7510, Q7520
    - U6900
    - Checked for shorted caps and bad resistors on the SMC_BC_ACOK line asper touch points indicated by Boardview
    I Have removed the following components in an attempt to get rid of the SMC_BC_ACOK short with no results. (I can't replace these as I am waiting for replacement parts to arrive)
    - Q7030, Q7035
    - U4900 (SMC)
    - Q6901
    Until I can figure out why there is no voltage showing on ADAPTER_SENSE I am pretty sure I will not be able to get PPBUS_G3H back either. Really baffling me at the moment, and hoping there is something obvious that I am missing? Could there be some sort of short inside the board that only shows up when powered?
    Any and all help appreciated!
    Thanks.
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
