Replacement mosfet for PK6H6BA ?
  • madfreak
    • Aug 2012
    • 135
    • Poland
    Hello everyone . Does anyone know a replacement mosfet for PK6H6BA ?
    I will be very grateful for any help, because i am searching that PK6H6BA and i did not find it in stores so the replacement is the only solution.
    Have a wonderful day
  • reformatt
    • Feb 2020
    • 1419
    Re: Replacement mosfet for PK6H6BA ?
    Datasheet is available, do a parametric search. AON6796 will probably suffice.
    • vienzen
      • Feb 2015
      • 112
      • PHILIPPINES
      Hello
      Did you find a replacement for that mosfet PK6H6BA?
      • satishkumar
        • Sep 2015
        • 164
        • India
        its a N-Channel Mosfet,
        use Any N-Channel mosfet
        • vienzen
          • Feb 2015
          • 112
          • PHILIPPINES
          Can I use AON6414A?
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            lIf the specs arethe same you can use it.
            • satishkumar
              • Sep 2015
              • 164
              • India
              yes
              • usyusy
                • Sep 2021
                • 171
                • Pakistan
                sir by the specs what we mean?
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  These specs
                  Regards vcc , id , rdson etc
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    https://logi.wiki/index.php/User:Pie...iginal_part.3F
                    • usyusy
                      • Sep 2021
                      • 171
                      • Pakistan
                      got it sir, thanks.. regards
                      • DoOm86
                        Dual mosfet replacement help
                        by DoOm86
                        Hello.
                        I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                        It seems to be a 30V dual asymmetric N-channel AlphaMos.
                        Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                        And here is where I need help!
                        It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                        I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                        Thanks!...
                        10-31-2023, 12:03 PM
                      • jm942
                        Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                        by jm942
                        My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                        I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                        I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                        I did voltage injection on the cpu with 0.7V and i have a current...
                        07-11-2024, 05:11 AM
                      • Jane
                        How do you test MOSFET in laptops ?
                        by Jane
                        I tried to use this method:
                        Testing an N-channel MOSFET:
                        Step 1: Discharge the Gate (turn off the MOSFET)
                        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                        Step 2: Charge the Gate (turn on the MOSFET)
                        Now, place the red probe on the Gate (G) and the black probe on the
                        09-27-2024, 03:31 AM
                      • String2016
                        SMD MOSFET REPLACEMENT
                        by String2016
                        Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                        01-23-2025, 06:35 PM
                      • String2016
                        by String2016
                        i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
                        12-15-2024, 05:31 AM
