acer nitro 5 515-51 no power
  • tikanot
    • Mar 2020
    • 67
    • france
    hello i have an acer nitro 5 515-51 no power, i have find a short in pq303 and pq304 , i have put 19V in pr304 and i don't find any cc but no power too. before chance pq303 and pq304 i need to know if other part is dead
  • mon2
    • 14673
    Re: acer nitro 5 515-51 no power
    Can you post the schematic for this logic board ? I did find 515-52 schematic in my sub but the part references are not the same.
    If the above are the first 2 mosfets that mate with the DCIN then remove all power. meter in resistance mode.
    Using this resistance mode, check if the mosfets are defective or not.
    Measure the resistance between:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    If you see 'OL' = over limit - then increase the resistance scale to the next higher setting on your meter and measure again.
    If you see a low resistance reading, the mosfet is defective and needs to be replaced.
    Repeat the test with the next mosfet.
    Post the readings.
    • JaroTech
      • Mar 2015
      • 351
      It's the same schematic as the Acer Aspire A715-71.
      • mon2
        • 14673
        Well noted. Now see the same mosfet references.
        Post the resistance values of the first 2 mosfets.
        • tikanot
          • Mar 2020
          • 67
          • france
          i have test it and i have find the two mosfet is dead
          • tikanot
            • Mar 2020
            • 67
            • france
            shortage is remove but no power.
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • aladin2l
              ACER NITRO 5 AN515-52 DH55VF LA-F591P POWER ON NO DISPLAY
              by aladin2l
              hello guys i have here ACER NITRO 5 AN515-52 DH55VF LA-F591P POWER ON NO DISPLAY i think it boots beacuse the keyboard lits the fan spin 2 times when power on because i think bios responces without cmos battery also when charger connected then charger plug in it also tones plug and replug my main problem is it wont display even in monitor
              heres my voltage and resistance reading for all the coil or inductors i hope someone can help me where to find the missing voltage on +VGA_CORE and +VCC_GT
              PL1302 1.3V
              PL7202 0.9V
              PL8301 1.0V
              PL8106 0.9V
              PL8305 0.9V
              PL8306...
              10-16-2024, 05:17 AM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
