A1466 / 820-3437-B / only starts on the 3rd attempt
  • GfilipeZ
    • May 2021
    • 43
    • Portugal
    I'm trying to detect a strange anomaly that keeps repeating itself in the same way.
    If i press the power button, the fan spins 1/4 and stops. I press the button again, and the fan spins normaly, but there is no boot. Then i force it to shutdown, and press the button for the 3r time, and the machine boots normaly.
    If i let the macbook turned off for about 20/30 min, the anomaly comes again, and i have to do all again to make it boots.
    I already tried an SMC from a donor logic board and dump a clean firmware to the EFI ic, but the problem always remains the same.
    Has anyone experienced a similar problem?
    Best regards.
  • GfilipeZ
    • May 2021
    • 43
    • Portugal
    Re: A1466 / 820-3437-B / only starts on the 3rd attempt
    Best regards.
    Any idea?
    • reformatt
      • Feb 2020
      • 1400
      Check for presence of PP3V3_S5_AVREF_SMC. If it's missing, usually a shorted cap next to the SMC. If this is missing, board will only start in SMC Bypass mode which sounds like what you are doing.
      • GfilipeZ
        • May 2021
        • 43
        • Portugal
        Best regards.
        I dumped another file with clean firmware to the EFI ic, and restored the Mac OS. Don't ask me how, but, solved my problem.
        Thanks guys.
        • chaos-theory
          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
          by chaos-theory
          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
          03-14-2025, 05:37 PM
        • arabex21
          Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
          by arabex21
          Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
          I have a problem with this configuration:
          ASUS PRIME B450M-A
          RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
          When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
          09-19-2024, 03:05 AM
        • psdavid65
          A1466 820-3437-B Bios Problem
          by psdavid65
          I received a 2013 Macbook Air A1466 A1466 820-3437-B motherboard WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
          06-18-2024, 05:26 AM
        • IamPritesh
          Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
          by IamPritesh
          I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
          Some very important points :
          • Laptop does not auto starts after shutdown if adapter is connected.
          • It will only auto start after shutdown if the laptop is in BATTERY only mode.
          • I have tried replacing batteries with a known
          • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
          09-24-2021, 05:01 AM
        • Sergio Kub
          MAcbook Air A1466 EMC 3178 - 2017 Boot
          by Sergio Kub
          Could someone help me?
          I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
          Could it be the BIOS?
          07-08-2025, 04:41 PM
