nb8513_mb_v3 no power
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi I have a board that no power passing to the Second mosfet.
    Ive check all the mosfet and coils no shorted areas.
    So I've decided to pump voltage to the second mosfet to the sensing resistor.
    No amps consuming.
    Shorting the power button.
    It will just take 40ma .
    And found out that the SY8286BRAC was getting hot. but not so hot because the board will just turn off after 5 sec. I was just using lighter fluid to confirm that it was getting short.
    I tried replacing it with a new ic but same problem
    I tried to remove the ic and check all pins for short but no short found
    I tried to clean the pads and reflow agian and check for short but nothing found.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • vexarvf1s
    Acer: No power after first MOSFET no short? Looking for guidance.
    by vexarvf1s
    Looking for guidance in tracking down missing main power rail.
    I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
    First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
    So checked for voltage on the gate of the first MOSFET and...
    05-13-2023, 07:55 AM
  • Thomas Smith
    Asus Tuf gaming fx506l no power, mosfet does not open
    by Thomas Smith
    Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
    Initial Symptoms:
    • The laptop has no power at all (no LEDs, no fan spin).
    • No 3.3V or 5V present on the board.
    • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
    Power Rail Checks:
    1. Charger input (FETs PKCH2BB)
      • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
    2. BQ24780S Charger IC:
      • VCC and ACDET are present.
      • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
      • Shunt resistor has 10Ω to ground.
    03-30-2025, 03:38 AM
