a replacement for intersil 95860hrtz
  • kjchatman
    • Dec 2012
    • 213
    • united states
    i have a 2020 model laptop with a 10th gen i7. LG Gram. 17z90n. It has liquid damage and a few traces are broken but more importantly the cpu voltage buck converter needs to be replaced. the chip is isl95860hrtz. Is there a compatible replacement that i can order from within the u.s.a.? this intersil chip can be found on aliexpress but i was hoping to get one quicker
  • mon2
    • 14660
    Re: a replacement for intersil 95860hrtz
    Unable to find anything local - contact Mobile Sentrix in the USA to see if they carry it.
    You can also try Louis' online store - he may have it but his focus is with Apple repair parts.
    Plan C is to use a 'rush courier' from Aliexpress but even they are slow these days. Our DHL shipments out of Shenzhen are taking 1-2 weeks.
    You may have to resort to Aliexpress...
    • the_rem
      Unknown transformer : how to find a good replacement part ?
      by the_rem
      Hello guys,
      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
      04-23-2025, 01:48 AM
    • ezenia
      PS4 controller left stick potentiometer replacement issue
      by ezenia
      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
      09-30-2023, 02:19 PM
    • boosti45
      Macbook pro logic board replacement parts quesion
      by boosti45
      i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
      08-21-2024, 05:23 AM
    • r2digital
      klipsch kda-500 amplifier suitable power supply capacitor replacement ?
      by r2digital
      I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
      04-18-2024, 03:50 PM
    • grimacelord
      MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
      by grimacelord
      I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
      12-11-2023, 11:13 AM
