MacBook Air A1370 charging issue
  • 74kieran
    • Dec 2021
    • 33
    • Uk
    I currently have a MacBook Air which the battery io board connector has just been replaced. It has a delay charge it says on the MacBook plugged in but not charging for the first 5-10min and then kicks in a start charging. ( I didn't test the laptop before the repair). It has a battery count of 667. Would this be the battery being on its way out or the new battery connector not soldered correctly? I would assume it's the battery as it does charge?
    Has anyone had any issues like this before?
  • mon2
    • Dec 2019
    • 14246
    Re: MacBook Air A1370 charging issue
    Is the battery an Apple original? The original battery had ratings of 500-1000 charge cycles.
    Any other brand is just luck if it can last this long.
    I would try another known good battery.
    You can try your luck with Amazon batteries - many compatible ones up there. You can always return it if the results are similar but in general but we have had good luck with next day sourcing.
    If still at fault, we can troubleshoot it then. Update this thread either way.
    • 74kieran
      • Dec 2021
      • 33
      • Uk
      Ok thanks. Will order a battery from Amazon.
      • piernov
        • Jan 2016
        • 4435
        • France
        Most of the random stuff from Amazon is complete garbage. May or may not work, may or may not die after 6 months, may or may not have a decent protection circuit…
        • mon2
          • Dec 2019
          • 14246
          Amazon is great way to test if the original battery is the fault. Can return it after testing.
          • piernov
            • Jan 2016
            • 4435
            • France
            If you get 3 bad batteries in a row, how can you confirm anything?
            • reformatt
              • Feb 2020
              • 1414
              My experience is that anything marketed as 'genuine' is likely to be anything but. The only genuine thing you'll ever see is one fished out of the reject bin at the factory (or a device pull).
              I have had some success with batteries actually promoted as aftermarket and differentiating themselves on that very fact. Still don't last anything like an original battery from Apple but I warn everyone of that before I ever fit one.
              • 74kieran
                • Dec 2021
                • 33
                • Uk
                It does the same thing with a new battery. Is there anything else which can cause this issue?
                • mon2
                  • Dec 2019
                  • 14246
                  Post the voltage on each contact of the battery pack while it is connected to the logic board.
                  Each battery back has a BMS board (battery management board) that communicates over I2C / SMBi interface. We want to be sure these lines are not stuck.
                  • 74kieran
                    • Dec 2021
                    • 33
                    • Uk
                    1 - ground
                    2- 7.1v
                    3- 7.2v
                    4- 7.2v
                    5- 3.2v
                    6- 3.2v
                    7- ground
                    8- ground
                    9- ground
                    10-ground
                    11-ground
                    The order is right the left when looking at the battery connector.
                    Strangely now the laptop will not work without the charger. But the charger is not charging the battery.
                    • mon2
                      • Dec 2019
                      • 14246
                      The A1370 chassis had different logic boards inside.
                      Can you confirm the 820-xxxx number marked on your logic board ?
                      Do you have the
                      820-2796 or
                      820-2855 or
                      820-3053 (LIO board so skip this) or
                      820-3024 ?
                      • mon2
                        • Dec 2019
                        • 14246
                        After posting the logic board # 820-xxxx number,
                        < the following are referenced to the 820-3024 schematic >
                        1) using only the battery, post the voltage of:
                        D6905 - pins # 1, 2, 3
                        (see attached)
                        2) voltage of PP3V42_G3H_REG (measure @ L6995, pin # 2).
                        3) R7051 - pin # 1
                        4) R7052 - pin # 1
                        5) Pin # 18 (CSOP) of U7000
                        6) Pin # 17 (CSON) of U7000
                        • 74kieran
                          • Dec 2021
                          • 33
                          • Uk
                          820-2855
                          • mon2
                            • Dec 2019
                            • 14246
                            Ok - I think your PP3V42_G3H_REG is low.
                            Can you confirm this voltage first ? It should be 3v42 if ok.
                            Check @ L6995, pin # 2.
                            If you do not see this voltage, remove all power, meter in resistance mode.
                            Check the resistance to ground of L6995, pin # 2.
                            Post the readings.
                            • 74kieran
                              • Dec 2021
                              • 33
                              • Uk
                              Is there a motherboard schematic which will help me locate the pins?
                              • mon2
                                • Dec 2019
                                • 14246
                                Yes. That is the purpose of the boardview file. Check around this forum, it should be available but if not, I can post it in a bit.
                                820-2855
                                https://www.badcaps.net/forum/showthread.php?t=68473
                                For the coil, just measure on both sides to be sure.
                                The pp3v42 rail is a required voltage and believe you are too low if 3v2.
                                • 74kieran
                                  • Dec 2021
                                  • 33
                                  • Uk
                                  L6995 is 3.42v
                                  • 74kieran
                                    • Dec 2021
                                    • 33
                                    • Uk
                                    D6905 - pin 1- 7.58v pin 2- 7.13v pin 3- 7.33v
                                    R7051 - pin # 1 - 7.36v
                                    R7052 - pin # 1- 7.36v
                                    Pin # 18 (CSOP) of U7000 - 0.10v
                                    Pin # 17 (CSON) of U7000- 0.10v
                                    • mon2
                                      • Dec 2019
                                      • 14246
                                      The PP3V42_G3H_REG voltage @ 3v42 is perfect.
                                      Can you confirm these readings again ? These are not correct.
                                      Be sure that you are selecting the proper pins on this square device (QFN package).
                                      Expecting the same voltage readings as you have posted for R7051 & R7052 to be reaching these pins on the U7000 IC.
                                      If indeed you are confident that you are reading these voltages, then power down. Meter in resistance mode (lowest scale).
                                      Measure the resistance from R7051, pin # 1 to pin #18 of U7000. This resistance value should be ~ 0 ohms since this is a direct PCB trace = wire.
                                      Measure the resistance from R7052, pin # 1 to pin #17 of U7000. This resistance value should be ~ 0 ohms since this is a direct PCB trace = wire.
                                      If indeed the resistance is high, this is a fault - the charger IC needs to see the same voltage readings through these pins as you have posted from the above resistors. This means the traces are broken between the resistor legs and U7000. Look for any visual damage - corrosion ??
                                      With the low voltage readings, the charger IC will shut OFF due to the device thinking that too much of a load on the charger legs since the voltage is close to 0 v.
                                      Take your time and care to measure on the pins of U7000. The boardview should help to locate the proper pin numbers.
                                      Need to run for some house repairs - will check back later.
                                      • 74kieran
                                        • Dec 2021
                                        • 33
                                        • Uk
                                        It seems to still be no voltage. I am going to have to get a better microscope as the magnifying tool I have isn't great.
                                        However, I have tried continuity on chip C7050. Would this cause me issues with seeing the voltage? If I check the resistance, I am getting zero from the the U7000 to the R7051 and R7052 chip.
                                        • drlarsen
                                          MacBook Air M1 A2337 battery/charging issue
                                          by drlarsen
                                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                          After some hours, the battery status did not improve. Restore via DFU did not help.
                                          I connected the power adapter to a Kill-a-Watt...
                                          07-17-2025, 02:35 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
                                        • Julian Bailey
                                          HP ProBook 445 G8 Battery not charging
                                          by Julian Bailey
                                          Hi all
                                          We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                          The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                          I have gone around the board with a MM and cant find anything
                                          Windows shows the battery fine,...
                                          10-11-2024, 10:34 AM
                                        • Schluchti45
                                          MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
                                          by Schluchti45
                                          i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
                                          Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
                                          11-18-2024, 02:05 AM
